Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-09-2002, 06:31 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
ZC tranny vs Si tranny
im talking to a engine shop now, and they have a ZC with tranny for $675
and $100 for an 89 LS ECU
he says the ZC tranny is better than the Si but i would need bigger axles
i know id need the axles if i went with the ZC tranny, but i thought the Si tranny would work... so i guess my question is: Will the Si tranny work on a ZC engine. IF the ZC tranny is better than the Si tranny,
either way im gonna need a new clutch with the clutch type depend on the tranny? and which set up would be better
ZC DOHC w/ ZC tranny on an LS ECU with new axles and clutch
or
ZC DOHC w/ Si tranny on an LS ECU with new clutch
this is a car i drive everyday so i dont want any probs down the road
so which is the best way to go?
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 04-10-2002, 07:51 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
the zc tranny is geared closer, so it has better acceleration....the drawback is that it rev's pretty high at highway speeds and can get annoying.... the si tranny works fine and you dont have to deal w/ axles and an intermediate shaft and shit... the optimum situation is the zc tranny w/ the si final drive...
...so if ya drive on the highway alot, keep the si...IMO
SOLD!
Old 04-10-2002, 09:30 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
If you want to see exactly what the difference will be, click here...
http://crx.honda-perf.org/math/index.html
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 04-12-2002, 07:27 AM
shadowboy's Avatar
shadowboy shadowboy is offline
Send a message via ICQ to shadowboy Send a message via AIM to shadowboy
actually the ZC tranny is closer spaced for smaller rpm drops between shifts.. but the final drive is much taller than the Si tranny, so it will rev lower on the highway.
the best performance setup would be to use a ZC tranny (for the equal length halfshafts) using the Si final drive to shorten the gearing a bit for better acceleration
in terms of revving high on the highway, doesnt bother me
at 80mph the integra is spinning a hair over 4000rpm in 5th gear, and the nissan is spinning a hair under 4000rpm in 5th (the CRX spins under 2500rpm )
Shawn
1979 Porsche 924S
1987 Honda CRX HF -- Project Chassis
1989 Acura Integra LS -- Project Parts Donor
Old 03-19-2003, 05:42 AM
nes1chil nes1chil is offline
zc tranny
i had to get the USDM 86-89 integra tranny to bolt to the ZC motor in my 87 civic si. the 84-87 si tranny will not bolt to the zc motor.
Old 04-15-2003, 08:56 PM
Parker Parker is offline
is cruising at 2500 at 80 such a bad thing? fuel economy is up, noise down... win win to me! of course, my zc engine and si tranny (90)are in an '80 civic so mileage is up anyway
