Old 05-06-2005, 11:52 AM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
Post When To Shift??
I have a b20b in my crx and i am wanting know is at what rpm should i shift???
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 05-06-2005, 12:15 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: When To Shift??
hmmmm...a guy in the 240 forum did the calculations for shift points....i'll have to search for it
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-06-2005, 12:16 PM
Re: When To Shift??
If U Find Sumthing Post It On Here Please
°Sä®GëNTö69°
Old 05-06-2005, 12:29 PM
BLU CIVIC's Avatar
調整器
Re: When To Shift??
ok...i think this need to be a stickie...but i'll put it in the FAQ...from what i see...u have to take in a lot of variables to get your ideal shift points...so what would go for you wouldn't go for someone else unless their car was exactly the same...so break out your calculator
http://www.slowgt.com/Calc1.htm
The name's Adrian
2011 CR-Z - Stock
Old 05-06-2005, 12:32 PM
Re: When To Shift??
Hey Thanks For The Help!!
°Sä®GëNTö69°
Old 05-06-2005, 12:41 PM
BLU CIVIC's Avatar
調整器
Re: When To Shift??
no prob
The name's Adrian
2011 CR-Z - Stock
Old 05-06-2005, 07:31 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: When To Shift??
whatever the stock shiftpoint is unless his engine is modified in some way and i dont mean bolt ons
Team Lonely Drivers
Old 05-06-2005, 07:39 PM
BLU CIVIC's Avatar
調整器
Re: When To Shift??
that calculation takes all those things into consideration
The name's Adrian
2011 CR-Z - Stock
Old 05-06-2005, 07:45 PM
Re: When To Shift??
too many factors to say that it would be taht for every single setup like that.
like i said stick to stock redline. only other real way is to go on a dyno
Team Lonely Drivers
Old 05-06-2005, 07:54 PM
BLU CIVIC's Avatar
調整器
Re: Re: When To Shift??
did you even click the link it takes into consideration your set-up and then gives your shift points
racing to reline isn't the smartest thing to do and you would loose to someone who shifts and stay in their powerband...which is what he is asking...anyone can race to redline but to stay ahead, keep your rpms from dropping so that you maximze your speed and power, you need to know your approximate shift points
The name's Adrian
2011 CR-Z - Stock
Old 05-06-2005, 08:05 PM
Re: When To Shift??
yeah i did click on it. so what rear end ratio is he going to put in there. he doesnt have a rear end ?
Team Lonely Drivers
Old 05-06-2005, 08:14 PM
BLU CIVIC's Avatar
調整器
Re: When To Shift??
itz a basis for him to go off of
Please bear in mind that these calculators are approximations only. Although the information is based on a 5.0 liter Mustang, it is general enough to apply to any car used for drag racing
The name's Adrian
2011 CR-Z - Stock
Old 05-06-2005, 09:11 PM
Re: When To Shift??
the calculations arent gonna be right because they are for a rwd car, not a fwd.
so you cant use that. like i said use stock or stick it on a dyno to see your power band and shift accordingly
Team Lonely Drivers
Old 05-07-2005, 12:42 AM
Kven's Avatar
Kven Kven is offline
Re: When To Shift??
well you cant always rely on theory vs. real life. i would just get it dynoed and shift where hp drops off. if you notice how some of the road racing drivers shift, they tend to shift a little higher than redline so when the revs drop, it still be in the power band.
btw, for rear-end ratio; use Final Drive ratio(pretty much same thing)
btw, which calculator are you guys looking at? there's one that asks a little about the engine, but also asks for a "shift point" so that wouldnt tell you when to shift. also, that calculator cant figure out the powerband of different motors(no calculators really can; too many variables(mainly cam/ignition timing though))
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 05-07-2005, 09:41 AM
BLU CIVIC's Avatar
調整器
on that site i think it said to shift 1.5 rpms above your ideal shift point
i was refering to that Evenly Spaced Transmission Gears for Off-the-line Gearing and Rear End Ratio calculatior...but it said it was an approximation...gotta start somewhere
The name's Adrian
2011 CR-Z - Stock
