Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-06-2005, 11:14 AM
4thgenracer 4thgenracer is offline
idle issue
my 86 prelude si is idling funny..it will jump up to 2 and go back down..some one said i am going to need a new throttle body
Old 05-06-2005, 08:53 PM
deadlikeme deadlikeme is offline
Re: idle issue
If it constantly goes up and down even after its warmed up....its either the iac (idle air control) valve...or the fast idle thermo valve.
Old 05-08-2005, 06:09 PM
ludesidrivr417 ludesidrivr417 is offline
Send a message via AIM to ludesidrivr417
Re: idle issue
you dont need a new throttle body, and most likely its not your iac, if its jumping like that it probly means your iac is working, sounds like a coolant problem, check your coolant levels, most likely it is an air pocket in you cooling system, i had the same prob with my car and i have seen the same in the older ludes as well, all have been coolant problems
Old 05-08-2005, 10:03 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: idle issue
i have an idle surge problem as well but mines a sensir ontop of the throttle body.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-09-2005, 05:24 PM
tetrahydro tetrahydro is offline
Banned
Re: Re: idle issue
make sure there is no leaks in the intake, and if you have an aftermarket one make sure the vacuum valve on the bottom is either used or patched that was causing me to idle at about 1200 rpms and now im idling at about 900 when warmed up
