Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 05-06-2005, 09:43 AM
r_dee_jay r_dee_jay is offline
Transmission Grinding
I have a 2001 ZTS and lately the Tranny has been grinding. While sitting at a light if I take it out of gear, then when the light turns green thorw it into first it grinds, then as I shift into second it grinds again. The other gears don't. What could be the problem? I believe that I'm the second owner and I have not had the tranny checked since I have had it. I would like any info that may help
Thank you
Old 05-06-2005, 04:32 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Re: Transmission Grinding
Worn synchros...? One of the few things that would actually grind, and since 1st and 2nd are the most used gears, that makes sense. How many miles?
-Chuck
Old 05-06-2005, 07:10 PM
Re: Re: Transmission Grinding
It has 57,447 miles on it. If it is the synchros, then what will I need to do to fix the problem. I believe that my after market warranty might cover this. I just need to know the main thing to look at so I can see if the warranty covers.
Old 05-06-2005, 08:16 PM
I wouldn't be sure if any warrenty would cover synchros, as I think that they're considered wear items, even though 54k miles is way to early for synchros to go. Regardless, at a minimum, the tranny needs to come out, and basically be taken apart. Keep in mind, that it may not be synchros, but that sounds likely considering the symptons you're describing.
-Chuck
