Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-06-2005, 02:59 AM
deadlikeme deadlikeme is offline
99 jetta running sluggish
My 99 jetta 2nd generation with the vr6/5spd is running sluggish. Also when checking the oil i smelled gas. Any suggestions? Maybe just needs new plugs?
Old 05-07-2005, 03:23 PM
pissboy's Avatar
pissboy pissboy is offline
uh you smell gas in your oil?
thats usually a sign of a bad piston ring.
change your oil and put new plugs in and check your oil after driving it around for alittle while. if you still smell gas in the oil, you might want to do a compression check on the cylinders. if you have bad compression than its probably a piston ring. is it burning oil or smoking?
Old 05-08-2005, 03:52 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
VR6 engines have lots of problems with coil pack being cracked. Buy a new one, it will help alot.
