Old 05-06-2005, 12:37 AM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
synthetic oil burning
i run mobil 1 10-30 synthetic, and i seem to go thru about 1.5 quarts between oil changes, no oil under the car, and the motor is only about 12,000 miles old, thats really new. anyone got any ideas, thers not smoke at all.
Old 05-06-2005, 01:27 AM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: synthetic oil burning
Have you ran synthetic the entire life of the motor?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 05-06-2005, 02:45 AM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
i would switch from the synthetic oil, it tends to be a little more thin than conventional oil, which is most likely what is causing it to burn
* i got my car at around 96k, and i had used synthetic oil in it until recently, when my car hit about 120k a local mechanic told me to switch to a high mileage oil because he said it would coat the components and protect a little better than synthetic.. I also add slick 50 engine treatment after every oil change.
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 05-06-2005, 08:09 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: synthetic oil burning
synthetic oil appears to be thinner because it is more consitant in viscosity. It is not thinner, if it was, it would have a different viscosity rating.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 05-06-2005, 12:05 PM
very true.. i didnt take that into consideration.
*being as how i am still a "beginner" of sorts.. i generally do go by feel and look..
Old 05-06-2005, 01:21 PM
Link85x Link85x is offline
This is definitely a noob question but how does the oil turn black? Is it becuase of the heat generated within the motor while the oil flowiin through it (i'm tryin to smart here).
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 05-07-2005, 09:36 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
The only other place it could go is in the coolant system. Open up the radiator cap and see if you can see oil floating on the top of the water in there. You could also check the spark plugs to see if any of them see to have some oil on them. Also check your tail pipe because if you are burning oil you'll be able to feel it inside of there.
It's pretty much dirt and other stuff like that. There are small bits and pieces of stuff that get sucked into the engine that the air filter and/or fuel filter can't get. After a while they work their way down the piston and get down into where all the oil is.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 05-08-2005, 03:07 AM
Morley Morley is offline
If yo uhave had synthetic oil in it since the engine was new/rebuilt, that may be the cause. Most engine builders reccomend that you use mineral base oil for the break in period (they say synthetics protect so well that the engine doesn't get to break in) then switch to synthetic if you want.
