Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 05-05-2005, 10:33 PM
janandkyle janandkyle is offline
Lightbulb What Engines
Hi all,
I have recently bought an 89 dodge daytona for $100.00, with a 2.5l tbi engine
that threw a rod. I would like to know which sizes, and year model engines can be put in without changing anything else. Im hoping to find an engine in a salvage yard that i can put in without too much trouble.
also a freind and i pulled the original engine from the top of the car with a cherry picker but it was a pain in the a**. will i be able to put one back in this way without damaging something?
A cherry picker is the only equipment i can get to lift with around here so i dont know how else i can do it.
your help is greatly apreciated
Old 05-05-2005, 11:07 PM
Re: What Engines
I forgot to add that it has a 5speed manual transaxle
Old 05-06-2005, 12:21 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
If you don't want to change anything else then you're going to have to find another 2.5L TBI. It would have to be an 89-94. I think they changed something in 1995.
You could always swap in any one of the turbo engines but you would want to pretty much swap everything under the hood.
Old 05-06-2005, 10:34 PM
Re: What Engines
Thanks for the fast response Polygon!
By the way, does it matter weather the car i get the engine from is auto or manual?
Sorry if this is a stupid question.
Also, love your lebaron, my best freind has a red 1992 model that looks just like it.
Old 05-09-2005, 02:42 PM
Polygon's Avatar
The Red Baron
Thanks for the compliment!
Anyhow, it doesn't matter if it is auto or manual.
Old 05-15-2005, 09:16 PM
Re: What Engines
i just bought another daytona for $100 that runs but needs a valve job. The body is a pile of junk so i wanted to put the engine into my 1989 which looks great and has a manual tranny!!! The problem is, the 92 appears to be dis (direct ignition system) and the 1989 has a distributor. What all will i have to take from the 92 model to make this work? Will i need to use the 1992 computer? will it work with the manual tranny? Could i possibly put my 1989 distributor into the 1992 engine to get around this?
Sorry for all the questions but i really want to get this thing running!
Old 05-16-2005, 01:18 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: What Engines
sounds like the '92 has the 2.2 Turbo III motor. Your best bet, if you're looking for an engine, find a 2.5 from either a Caravan, Dodge Spirit or Dodge Shadow.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-16-2005, 09:57 AM
Re: What Engines
no, the 92 is throttle body injected. maybe i was mistaken and it has a distributor. but if it is a distributor it definately looks different than the one off my 89 daytona.
Thanks for all the help!
Old 05-26-2005, 11:34 AM
AWP9521 AWP9521 is offline
Re: What Engines
If the 92 distributor connections are the same as the 89 harness then you can use it, if not you can swap the 89 distributor in it's place and it will work fine.
Old 05-27-2005, 09:26 AM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: What Engines
A good site for finding used parts and give you an idea what the interchange is like, check out http://car-part.com/
Old 05-31-2005, 10:29 PM
Re: What Engines
Thanks everyone for all the help.
I just decided to use the ditributor from the 89 as you said and will let you know how it all works out in the next week or two when i get the engine in the car. Again thank everyone for the help!!!!
