Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 05-05-2005, 11:18 PM
TomsAero TomsAero is offline
extremely important, please help
ok, so i screwed up and took my van to the wrong trans place. now the transmission shifts WAYYYYYYYYY too high. what are the regular shift point for the ford aerostar A4LD? i have the 4WD model. this will help me a ton. thanks guys.
the place rebuilt the trans, but it isnt shifting right, it doesnt hold a gear, it is very annoying. i have an appointment for tomorrow, so hopefully, everything goes smoothly. the idiot is like, "oh, ill set it to whatever you want". Im like, well, id like it in the stock locations. he responds with, "tell me where you want it, and ill set it there."
i have the worst luck.
Old 06-10-2005, 11:27 PM
Ima Ludite Ima Ludite is offline
For 1990 A4LD
- In O/D = 10" Hg vacuum
- In 3rd gear = over 45 mph should shift into 2nd when selector moved from D to 2nd.
- If going over 45 mph and in O/D and selector is moved from O/D or D to 1 (closed throttle) it should shift down to 2nd greer and if below 30 mph it should downshift into 1st
- For a coastdown from 45 mph in D and throttle closed the downshift sequence is as follows: converter clutch unlocks eletronically when the accelerator is released, as vehicle slows down, 4-3, 3-2 and finally 2-1 downshifts happen. Section A4LD Transmission 07-01A-13. For upshifts look in TSB "Performance Specifications Book" Good Luck, Brian
Old 07-21-2005, 04:01 AM
Transmission is now fixed. The problem was a bad repair job by the shop. I had another location look at it and they ended up fixing it right this time. Plus i got a whole slue of new parts for free.
