Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-05-2005, 08:43 PM
n2racing n2racing is offline
Pass Key Fault 94 Caprice
I went out to start my car which was starting every time until now. The car won't do anything past the on position. The Pass Key fault light remains on. Any suggestions or experience with this in the past?
Thanks.
Old 05-12-2005, 09:59 PM
10sec.et 10sec.et is offline
Re: Pass Key Fault 94 Caprice
sounds like a battery connection problem. if it has a delco battery they like to leak acid out around the pos terminal. thus causing a bad connection. as far as the pass-lock system, they usually start and die every time. hope this helps
Old 05-16-2005, 07:54 AM
radioman2002 radioman2002 is offline
If it's not the battery, try a different key. Otherwise, to disable the PassKey system, you will have to read the Passkey resistance and just jump the system out in the steering column.
