Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-05-2005, 08:59 PM
NIX396 NIX396 is offline
Vibration at speed
Just replaced all tie rods,pitman,idler,and a couple of ball joints. Drove it after repair and was pulling right. The tire shop did some switcheroo on the tires and fixed that problem. Now at around 35mph it starts vibrating and gets worse as i speed up. Do any of you agree that it should be a balancing issue???? The tires are fairly new bfg a/t ko. If not balancing, would the next step be u-joints then hubs?? The hubs are supposedly good...Thanks!!!!
Old 05-06-2005, 06:08 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Vibration at speed
Is your ass vibrating or the steering wheel?
Old 05-06-2005, 10:40 AM
sherman69 sherman69 is offline
bounce
Hi,
If they swapped the tires around and not replace one, then you probably have one with a broken belt. This can cause bouncing also. Might even be able to see it with close inspection, a slightly bulging area.
Bob B
Old 05-06-2005, 03:09 PM
Kevcules Kevcules is offline
1-I've never heard of changing parts to "cause" a vibration??
2- It does sound like tire failure.
3-Stay away from a garage that "re-arranges" tires to get rid of vibration!!!
Kevin
