Old 05-05-2005, 07:46 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
b18 Swap HELP NO SPARK!
Ok i got everything hooked up now. I turn over the engine and i have fuel and compression but no spark. Also the gauge cluster's lights don't come on either except the seatbelt light.
This is what i have if it helps, 94 B18 engine, OBD-1 Conversion harness, using the civic DX harness.
Help me please!!
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-05-2005, 07:59 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: b18 Swap HELP NO SPARK!
double check all of your grounds, there should be on from the battery to the frame, one from the wiring harness to the thermostat housing, and one from the valve cover or I use the block to the frame.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 05-05-2005, 08:30 PM
yea im pretty sure they are all hooked up but i will double check. The car still turns over though and the fuel pump comes on but no spark and the gauge cluster lights dont come on.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-06-2005, 12:04 AM
OK the gauge cluster works now, I just swaped it with another one turns out the old one was bad. Anyway I STILL DONT HAVE SPARK!! Can any one help me with this? I checked my grounds, wires, stuff like that but there is no coil to check so im out of ideas.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-06-2005, 07:38 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
The coil is an internal part of the dizzy. You can test it. There is an ignitor on the bottom of the dizzy that goes bad sometimes.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-06-2005, 08:42 AM
travagliante's Avatar
travagliante travagliante is offline
firing order? got the plugs in the right order?
sorry cant help much more!
got the tranny ground and engine ground?
good luck!
Old 05-06-2005, 09:48 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
you did the mpfi swap, switch the 2 white wires on the dist plug and see if that fixes it
Team Lonely Drivers
