Old 05-05-2005, 05:17 PM
chembrad chembrad is offline
High mileage Honda just purchased
Hey folks. I just picked up a '93 Civic DX Coupe w/ AT. Only ding against it is that it has 232,000 miles on it.
This is the first Honda I've had (since my 1972 CB350G ).
What kind of problems are typical for this mileage on this model? Any help is appreciated. Thanks!
'05 Dodge Grand Caravan 105k miles
'94 Geo Metro 1.0L 5spd 185k miles... at least I can fix it!
Old 05-05-2005, 05:21 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: High mileage Honda just purchased
lol I just got the same car for a beater.
I changed all my fluids/plugs new battery checked my hoses thats about it..Runs like a champ but I got less then half the miles. Only paid a grand for it - good luck with it.
03.IS300.MT.LSD. 'Supra in Training'
Old 05-05-2005, 08:14 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
gas mileage will depend on your maintenence. engine health will depend on your compression and leakdown.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-06-2005, 01:36 AM
BullShifter's Avatar
Re: Re: High mileage Honda just purchased
The biggest issue is the timing belt. If you don't know the last time it was replaced it wouldn't be a bad idea to change it.
Timing belt
Water pump
Drive belts
Seals*
Plugs, cap/rotor, wires*, fluids are all important too.
Other than that, rust is the biggest problem. Coil springs tend to break easily on mid 90's Honda's, check those.
As long as it's taken care it should last a lot longer. I've seen over 400K on a civic & over 600K on an Accord, both with orginal engines and transmissions.
Old 05-06-2005, 10:32 AM
polacek's Avatar
polacek polacek is offline
CVJ boots might be bad. Replaced one at ~180k and the other @ ~185K ($25 each). Front disc brakes might be bad. (~$30 each) As long as the oil is at about the same level between oil changes, you are good to go. Check timing and valve clearance (free, if you do it yourself). Got 220k on mine with all original equipment, except for shocks/struts/springs, filter's, fluid etc.
Old 05-14-2005, 02:42 AM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
OMG, a 200,000 mile DX. I can't beleive the car still starts......
Any way. Like JackAssSi said!
Ya, It's Turboed.
Old 05-14-2005, 08:29 AM
Re: Re: Re: High mileage Honda just purchased
Timing belt
Water pump
Drive belts
Seals*
Thanks for the tips. Sounds like no real problematic issues with these vehicles then other than normal maintenance.
The CV boots are in excellent shape. Good elasticity with no cracking in the boot.
cheers!
Old 05-14-2005, 02:33 PM
jeffseby's Avatar
Ya, alot of stuff may be needed at the begining, but soon, you will be back to regular maintenance.
Also, if your car wont start one day.....find out what the main relay is, and replace it. The main relay is by the driver side kick panel, and controls most of the fuel system, such as the fuel pump. I am just saying this, because it is very common problem in older Hondas.
But remember....you have a Honda!!!
Ya, It's Turboed.
Old 05-15-2005, 12:55 AM
polacek's Avatar
Of course it still starts. There are honda's out there with 300k, 400k even 500k miles on them. I am just breaking it in.
