Old 04-09-2002, 02:15 PM
mhpspeed mhpspeed is offline
Send a message via AIM to mhpspeed
roll cage's
I was just wondering if some body can give me a tip on building models with roll cages. Everytime i build a model with a roll cag it looks perfect untill im ready to put the body and when i dry fit it the body wont go all the down over the chassis. Dose aybody else have this problem or knoe how i can prevent this?
Thanks,
MikE
Old 04-10-2002, 06:11 AM
flyonthewall's Avatar
Car Mod guy
Which model manufacturers are they from??? I haven't had this problem with tamiya kits so far and have not had to remedy it. I would advise to dry fit the set up before painting to check for a problem. Its likely to be the thickness of the 'glass' that causes the problem so i think the only way to go about it is to reduce the height of the cage. If i came across this situation i might attempt to lower it by cutting through selected parts with a razor saw. As the saw cuts through the plastic it is removing a small amount so when its stuck back together it will be shorter than the original piece. If u cut through the vertical bars at the lower part of the cage and do so carefully, it should be the same height all around!!! if u dont have one of these saws then perhaps u could sand away at the bottom of the pilars and then replace any locating pins - if there are any?
Old 04-10-2002, 06:20 AM
thanks I will try this and it is a tamiya kit. I have had truble with the subaru impreza wrc 2001 and the piaa honda accord.
Old 04-10-2002, 06:32 AM
daggerlee's Avatar
Your paint and primer might be too thick..
Dan
Old 04-10-2002, 07:58 AM
primera man's Avatar
"P-Man"
F.O.T.W....Ditto to what he said.
Ive never struck this problem before with any of the roll cages i have built.
If i do have a problem its with the Revell/Monagram one's that dont fit together very well.
View All My Models Here.
Old 04-13-2002, 01:10 PM
thans guys for all ur help!!! I trimmed up the roll cages an they fit perfectlly
Old 04-13-2002, 02:13 PM
Car Mod guy
So how did u do it?
Old 04-13-2002, 04:36 PM
I trimmed a little from the bottom and the and it still didnt fit and then i looked again and found a ball of glue on the top where they connected and trimmed that off.
