Re: shut off and check engine and oil light comes on
Hard to say, those lights will come on the instant the motor dies for any reason, so that in itself is meaningless.
Generally, when a motor stalls when the brakes are applied, it is due to a lean idle mixture issue, the vacuum demand from the brake booster overwhelms it momentarily.
However, since you mentioned battery and alternator, I wonder how recently it was done. I know on GM cars, when you disconnect the battery for more than a few minutes, the computer looses it's learned idle strategy. Then when it is driven again, it will idle too high, too low, or exibit a rolling idle, and is prone to stalling when the throttle is dropped. This continues until the ECM is reset, or the car can just be driven and it will relearn the idle strategy on the fly. Sometimes it takes a few times of being driven before they shape up.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
