Old 05-05-2005, 12:00 PM
diy-dad diy-dad is offline
Question Code 43
I have a code 43 on my 89 astro. Wondering how I find the exact problem. In the manual a Code 43 is either low voltage in EST (electronic spark timing) or ESC (electronic spark controller). On a website I went to it said a Code 43 was the ECM not detecting a knock signal at near wide open throttle at coolant temperature above 194 degrees. I have never owned a vehicle with so many sensors before and I feel a bit over-whelmed when this stuff happens. Does it involve testing with a volt meter or is there another way. Any help is much appreciated. Thanx
The older I get the younger I was.
Old 05-05-2005, 08:31 PM
Kings-x59 Kings-x59 is offline
Re: Code 43
Wide open throttle above 194 degrees? I discern from your nickname that you are unlikely to drive your van at wide open throttle. Something seems akimbo about that code description.
My Haynes manual indicates code 43 for the ESC only. Otherwise known as the knock sensor.
If you have a digital multimeter you can certainly test the sensor. If it's the original sensor on your '89 it's a fair bet it's given up the ghost.
However, the knock sensor on an '89 gets pretty gunked up. I know, I have an '89 too. For starters you could clean it up, and make sure the connector is making good contact. if that doesn't do it, the sensor is about 29 bucks to replace.
Old 05-05-2005, 09:04 PM
CD Smalley CD Smalley is offline
Re: Code 43
I had a knock sensor go and give that code too.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-06-2005, 12:17 PM
Thanks for your replies. I was getting some of the code descriptions from the manual that came with my code reader and some from a website. Glad I asked the question here. Take care.
