Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-05-2005, 09:43 AM
camch camch is offline
soft brake pedal
i have replaced calipers and hoses on my 3500 and cannot get the brakes to pump up properly,,the pedal goes to the floor,does the brake booster if its not working properly have anything to do with this thank,i know the brakes are blead properly,andhas anyone had any problem with the 2 check valves
Old 05-09-2005, 08:33 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: soft brake pedal
1. Check level in brake fluid reservoir
2. Insure tight connections and look for leaks
3. Re-bleed and test.
There has to be some leak, somewhere if this happened after the new brakes were installed.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-18-2005, 08:10 AM
brakes atten fred
the pedal was soft before i changed calipers and hoses,adjusted rear brakes and still have soft pedal,could booster cause,pedal is soft at top goes down about 4 inches then gets hard thanks
Old 05-18-2005, 08:41 AM
4 inches? Wow, that's a lot.
I'd suspect the master cylinder. What year is your 3500? If it's still under warranty it's time to let the dealer pay for it.
Old 05-18-2005, 03:57 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: soft brake pedal
is your truck a diesel? If so you need to have it running when you bleed your brakes.
Old 05-19-2005, 05:41 AM
galea_joe galea_joe is offline
I know this might be way out but are your rotors and drums the right size and not turned to big (for drums) or too small (for rotors). I have had a vehicle in the past that had a very low brake pedal and come to find out one drum was cut too big that the brake cylinders were expanding to their maximum and resulted in a low brake pedal!
Old 05-19-2005, 07:32 AM
i have found that the calipers are sucking in air through the bleeders it is not leeking fluid but is sucking in air,thanks for all sugestions
Old 05-19-2005, 07:36 AM
Dam; so all this time you've been having air going IN through the bleed ports? Wow. Hope you weren't driving it.....
Old 05-19-2005, 09:43 AM
yes it was pulling through bleeder ports,but no fluid coming out ,now it is pulling under braking to right,rt front smoking after heavy braking,and no did not drive in untill now
Old 05-19-2005, 09:44 AM
Probably needs to be bled more on the left front. You probably did already, but make sure the reservoir is full.
