Old 05-05-2005, 09:01 AM
OJDee's Avatar
OJDee OJDee is offline
Help with deformed body
Hi
I've just received a Fujimi Gallardo from HK and it looks like it was crushed a little in transit.
The roof has been pushed down a bit and the two a pillars are slightly bent. Does anyone have any tips to get these back into shape. I was thinking something along the lines of heating the plastic a little and using splints of some kind to get it to sit back at the correct height. Maybe the windows will make it confirm again?
What have you done in similar circumstances?
Cheers
Oli
Old 05-05-2005, 10:02 AM
Scale-Master's Avatar
Scale-Master Scale-Master is online now
Sometimes if the pillars are not kinked, just bowed, and the windshield fits well, you can cement the glass in after you finish painting it and it will hold the shape of the posts.
I have used thin wire and thin left over PE strips cemented with CA to strengthen the posts too, but those look very thin and that may not be a viable option... - Mark
Old 05-05-2005, 10:41 AM
sirvtec1600's Avatar
sirvtec1600 sirvtec1600 is offline
Re: Help with deformed body
I use hair dryer, it works alright for me
Dom
Old 05-05-2005, 12:29 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
warm it gently in warm water and massage them back in place
Freakin' Groovin"
Old 05-05-2005, 01:31 PM
mrceej mrceej is offline
i've tried the water technique. i ran it for a couple of seconds under hot water to soften the plastic a bit. then i put the window in place to get the pillars to form correctly and held it tightly as i ran under cold water.
Old 05-05-2005, 01:54 PM
OJDee's Avatar
Thanks guys I will give it a go.
Since there seem to be some here that have built this model, did you use the supplied clear parts painted smoke to represent the mesh grills front and back and did it look okay?
Is there an alternative real mesh product that i could use for these areas?
Cheers
Oli
Old 05-05-2005, 02:28 PM
Vric's Avatar
Vric Vric is offline
warm water or ask for a replacement (if it's HLJ, they will give you one)
Old 05-05-2005, 02:58 PM
ZoomZoomMX-5's Avatar
I'd definitely try the warm (sub-boiling) water technique, combined w/carefully fitting the glass...the glass itself on the Gallardo is a very tight fit, the windshield is very tight near the base, and the side glass needs some sanding to get it to fit. So w/the right tension and perhaps a bit of hot water helping, the pillars may look perfectly okay if they haven't been kinked. Otherwise, HLJ can get replacements, though if you didn't get it from them, you'll have to pay for the body. They do provide free replacements when you can document a damaged shipment from them-pictures help. I got a fresh Hasegawa Miura when mine came damaged w/several trees broken and a few parts damaged. It's salvageable (some work will be very tricky), but it was very nice to get a perfect one to build.
The grilles should be painted flat black, they don't look right in smoke-there are some photoetch pieces available for it, but I hear they don't fit well. While it seems cheap to do the grilles the way they do, they look fine if they're sprayed w/flat black. Airbrushed flat black acrylic is best, to keep from filling in the fine mesh.
My Fotki Album
Old 05-05-2005, 03:20 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
warm water i find works the best
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-06-2005, 08:00 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Re: Re: Help with deformed body
This sounds like the best solution to me!
