Go Back   Automotive Forums Car Chat > Volkswagen > Older Vehicles > Corrado
Old 05-05-2005, 08:20 AM
jaxdubs jaxdubs is offline
Running Rich
I have a 93 Corrado with a 2.9L. I was involved in an accident a few month back and have been having this problem ever since. The car runs about 50 -100 rpms below normal idle and it runs way rich. I get a CEL saying that I have an O2 sensor fault saying overregulation. I have changed the O2 sensor, the MAF, the ISV, plugs and wires, blue temp sensor both knock sensors. Basically I am down to thinking I have an exhaust leak between the block and cat but I don't hear anything but I do smell it.
The O2 fault doesn't come on till the car has warmed up quite a bit. Once the CEL comes on, the idle somewhat stabilizes. It is still low but doesn't bounce so much that the car stalls.
I guess what I'm asking is, will an exhaust leak or even a clogged cat cause these symptoms?
www.jaxdubs.com
Old 05-25-2005, 01:24 PM
boschmann boschmann is offline
Re: Running Rich
I'd try a new coolant temp sensor, they're cheap & easy to replace. To test the sensor w/ohmmeter on the two sensor pins you should get 2000-3000 Ohms cold & 200-300 Ohms at operating temp.
Old 07-14-2005, 12:59 AM
Non_affiliated Non_affiliated is offline
Re: Running Rich
How are the RPM's driving, does it rev up then not go any further, usally that is a sign of a plugged cat, that and that wretched egg smell.
