Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-05-2005, 08:10 AM
kxs650 kxs650 is offline
1989 V-6 Dakota Won't Start
Thanks in advance to anybody who can help me with this!
This started a few months ago when I went out to take my for a drive and it wouldn't start. I tried putting gas in it and then it started so I figured maybe it had a gas leak or something. Then I went and filled it with gas, but I haven't seen or smelled any gas so I don't think that is the problem.
The next time I went to drive it, it started and I got a couple miles down the road and it just died while I was going down the road. It wouldn't start back up so I waited about 15 minutes and then its started and again so I drove back home.
Since then I have changed the spark plugs, spark plug wires, rotar, distributor cap and the fuel filter. When I turn the key one click I can hear what sounds like the fuel pump turning on, so I don't think that's the problem, but it could be.
I have gotten it to start a couple times since then and when it starts it runs better than it has since I've owned it, although a couple of times I got into the gas pretty hard just after I started it while it was idling and it died and wouldn't re-start. Other times I have let it idle for a couple minutes and then I can get into the gas as hard as I want.
The last few times I've tried starting it, it won't start. The engine turns over just fine, but it never starts. My Dakota has 128,000 miles on it.
I don't remember the specific codes it spit out, but I also tried turning the key on and off 3 times and counting the number of "Check Engine" light flashes. One of the codes indicated that an ignition spark sensor or something to that might not be working. Can somebody explain to me how to find that sensor and on a scale of 1-10 how easy it would be to replace?
Old 05-05-2005, 10:15 AM
davemc53 davemc53 is offline
This is a longshot, but my '89 was doing the same thing. We discovered a small wire in the distributor that was not connected properly. It would cut out when I was going down the road. I would sit for a few minutes and it would start. But more than likely it is the ECU (ECM).
Old 05-05-2005, 12:40 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: 1989 V-6 Dakota Won't Start
Sounds to me like your cam sensor may be going bad. Also have you check fuel pressure?
Old 07-01-2005, 10:48 PM
Olesniper Olesniper is offline
Been there. My Dakota was doing the same thing a couple of years ago. The problem was the "Hall Effect Device". It's a small round plate in the bottom of the distributor, under the rotor. The parts stores don't carry them, dealer item. You can find out more in a Haynes manual.
