Old 05-05-2005, 07:57 AM
mgs2006 mgs2006 is offline
flooring it
is flooring the engine every now and then to have a little fun on hilly roads all that bad for the car? what can i damage by doing that, etc, etc...
Old 05-06-2005, 12:36 AM
JTrujillo86 JTrujillo86 is offline
Re: flooring it
I consider that good exercise for the car...I do it around here.
Jeremy
Old 05-06-2005, 06:39 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: flooring it
Flooring your car isn't neccesarily bad, unless you were to do it too often. Obviously, when your generating more power at a higher RPM, you wear engine parts quicker - but you'll be alright if you don't do it all the time. You shouldn't need to redline it either - you should only be revving just past your torque peak.
