Old 05-05-2005, 07:56 AM
escort_jay102 escort_jay102 is offline
Gas Mileage
I have a 93 LX with a 1.9L and I recently changed the fuel filter on it. When I filled up the needle goes past the F mark.. Before I changed the fuel filter between the time from the needle past the F mark, to right on the F mark, I get around 60 miles. Just recently I got 95miles during that time. Those 95miles were on highway, then when i got in to the city it wasnt acting all that great. I ended up getting 236.7 miles onn 7.8 gallons of gas. Which would be 30mpg. If i stayed on the highway would I see a greater increase in gas mileage?
Another thing. My cruise control wont work, i want to fix it. What do I do to go about fixing the problem?
Thanks
1998 Chevy Cavalier
2.2/ K&N/ Ractive muffler
1994 Chevy s10
thrush welded muffler
Old 05-05-2005, 10:33 AM
RatLabGuy's Avatar
RatLabGuy RatLabGuy is offline
Send a message via AIM to RatLabGuy
Re: Gas Mileage
Honestly it is really hard to measure average gas mileage unless you are comparing complete tank to one another, as opposed to just the distance from Past F to F etc. In otehr words, do you normally get 30 mpg?
Yes, you will almost always get better gas mileage on the highway than around the.
As far as cruise control not working, mine dosn't either, and its b/c the pressure bottle has a leak/broken at the valve. Take a look under the hood at this, on mine ('95) it is on the pass side just behind the coolant overflow/filler tank... its kinda a weird system, but switching it on/off relies on pressure in this bottle.
Old 05-05-2005, 11:33 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Re: Gas Mileage
I agree mileage is subjective. However you will get better on highway then in town driving. At least in my '99 there is a big difference with highway mileage and in town. (but still better then in my nova)
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 05-05-2005, 03:35 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: Re: Re: Gas Mileage
nomatter what hghway is better tahn city, unless your doing 120 then not so much. but as far as the cruise, as stated the cruise is controlled by vaccum hoses which finding where the leak is could take a while...or you could just check the fuse for starters.
Old 05-08-2005, 01:22 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Gas Mileage
Here's a weird one, with Diesel's (Yes Ford used to make a diesel Escort, and they were incredible cars) they have basicly the same mileage weather it's in the city or highway. Basically 50mpg
Downtown LA rush hour would probably make a big difference though
Old 05-13-2005, 03:34 PM
sixleggedinsect sixleggedinsect is offline
Re: Gas Mileage
Originally Posted by escort_jay102
[color=blue]I have a 93 LX with a 1.9L and I recently changed the fuel filter on it. When I filled up the needle goes past the F mark.. Before I changed the fuel filter between the time from the needle past the F mark, to right on the F mark, I get around 60 miles. Just recently I got 95miles during that time.
gauging mileage by the needle is about the most innacurate way to do it, i figure. for instance, my 93 lx gets anywhere from 30 to 100 miles from full tank to needle on "F" depending on who knows how many variables, none of which i understand, including karma, planetary alignment, feng shui principles, and whether or not i am in a good mood.
seriously.
anthony
Old 05-13-2005, 09:31 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
put a new set of plug wires on as well as plugs, and an air filter. If you have any mechanical skills, take off the air box and cut a hole in the bottom of it(as well as remove the air silencer).
I did that and I got 34mpg thrashing my 91 1.9L/5speed car up and down the backroads of PA(hill country too to boot). As far as "highway" miles, I only have been back and forth from Lancaster PA to Washington DC and I still get 38mpg even sitting in traffic from time to time(rush hour). Not to shabby..that's why I love that little econocrapbox
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 05-14-2005, 05:45 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Gas Mileage
Thanks
I have the SPI SOHC 2.0 and get 91 miles between a fill up and the F mark on the gauge. I live in a rural area so don't do any stop and go driving. On your cruise control check the Meter fuse and the Stop fuse. These both have to work. All the best. Dave
Old 05-17-2005, 09:28 AM
when I cut a hole in the air box, how big does it have to be and where exactly does it have to be. and where is the air silencer that i have to remove? thanks
1998 Chevy Cavalier
1994 Chevy s10
Old 05-17-2005, 11:46 AM
Banned
Re: Gas Mileage
When I was young we filled our air boxxes with several 1/2" or bigger holes.
You can actually make it as big as possible, anywhere on the bottom that it won't be blocked.
The several smaller holes will stop garbage from getting sucked up in there
Old 05-17-2005, 09:48 PM
chevyn0va1's Avatar
Re: Gas Mileage
see my web page to show you how to remove it. My car had a hole at the bottom of the air cone that I left open I didnt make anymore holes.
