Old 05-04-2005, 09:46 PM
jlshondacrx90 jlshondacrx90 is offline
b16a1 questions? clutch speedo cable rear mount
i was wondering does the speedometer,and cluch cable need to be replaced with something different liek an acura part?
and do i have to remove my x-member to get the rear engine mount off?
Old 05-04-2005, 10:43 PM
Jdm 4G-EF9 Jdm 4G-EF9 is offline
Send a message via MSN to Jdm 4G-EF9
Re: b16a1 questions? clutch speedo cable rear mount
You don't have to change anything,but your engine mounts
Old 05-05-2005, 12:38 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
you dont need to remove the crossmember, but if you loosen the crossmember bolts and let the crossmember drop down an inch or so, itll make that back motor mount bolt a lot easier to get to
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-05-2005, 01:14 PM
IntegraB16 IntegraB16 is offline
My friend has a 90' CRX HF that we just put a B16a in, We had to replace the clutch and throttle cables, as well as the motor mounts. The motor mount kit only came with the back and sides. The front motor mount was waaayyy of and could not be hooked up. We also had to make some custom shift linkage and use 90-93 integra axles. I don't know if all that would be the same for yours... But i hope it helps.
