Old 05-04-2005, 07:31 PM
makaveli3004 makaveli3004 is offline
wiring 2 amps 2 batterys 2 caps??
hey i have a question can someone please describe all the connectionms i need to hook up my car battery to an after market battery which connects to 2 power caps which will run to 2 amps
http://members.cardomain.com/makaveli3004 My 97 Camry
Old 05-04-2005, 09:03 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: wiring 2 amps 2 batterys 2 caps??
you don't need caps they're useless as far as the second battery goes just wire the + of the other battery to the + of the batt and then ground the batt to a ground.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 05-05-2005, 12:10 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
yea, if you're going for SPL (boom) then the caps will be useless. They are only good if you like to listen to real recorded music .... i.e. not electronically produced bass tones.
Old 05-05-2005, 12:34 PM
okay well i have the caps might as well hook them up. how do i wire this now do i run the wire from my engine battery through an inline fuse to the battery in the back then put another fuse from that battery to the caps or is that unesssacery.
Old 05-10-2005, 09:34 PM
Audio Guy
do NOT fuse caps. Run a wire from the 2nd battery + terminal to the + term on the cap, then from the + term on the cap to the amp. Wire the - term on the cap to chassis gound.
Old 05-11-2005, 02:22 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
where exactly are you sposed to ground your amp? ive got mine grounded to the back of the trunk, but it seems to be causing feed back, are there special locations made for being grounded on?
Old 05-11-2005, 04:44 PM
Audio Guy
The grounding point needs to be bare metal ....... take the screw/bolt out and sand it down thoroughly
Old 05-11-2005, 04:46 PM
Audio Guy
The grounding point needs to be bare metal ....... take the screw/bolt out and sand it down thoroughly (the place around the screw/bolt hole)
Old 05-11-2005, 05:36 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
hahaha even Paul double posts some times
