Old 05-04-2005, 05:16 PM
CIVIC_03 CIVIC_03 is offline
blinking lights
i have a 90 crx dx. ever since i bought it the lights on the car has always been blinking. i mean like every part that has a bulb will blink lightly such as headlights, cluster, backlights, sterio lights, just every where is blinking. anybody know why this is happening??
Old 05-04-2005, 05:27 PM
IntegraB16 IntegraB16 is offline
Re: blinking lights
Sounds like a loose wire or bad connection somewhere.
Old 05-04-2005, 08:36 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: blinking lights
is it a constant rythmic blink? fast or slow? only on bumps? does it do it more/less with more/less things turned on? increase w/ engine rpms? steady no matter how fast or slow? only when the car is running or even when the car is off?
there r a LOT of specifics u left out in order for anyone to be able to give u a very accurate diagnosis. try a little more detail.
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
Old 05-05-2005, 04:49 PM
Randy_che Randy_che is offline
Re: blinking lights
Loose ground cable or loose battery cable. Also, make sure the battery terminals are both solid, and not loose in the battery itself.
Old 05-05-2005, 06:51 PM
Re: blinking lights
The Blinks Are Constant. Once The Car Starts The Lights Are Constantly Blinking At The Same Rate. Doesnt Go Faster Or Slower. Still Blinks The Same Rate When The Car Is Moving Also. Another Thing Is, The Car Keeps Dying While Driving. All Power Are Just Shut Off. Then I Have To Park For A Like A 5 Min And Then It Will Start Again. Whats Up With That
Old 05-05-2005, 10:14 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: blinking lights
Almost sounds like a loose ground or bad battery connection. As the engine bay gets hot, the metal (like your battery terminals) warms and and expands causing an even worse connection to the battery. Try removing, cleaning and reinstalling your battery terminals and checking the grounds - that is where I would start.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 05-05-2005, 10:28 PM
Gitrdone42 Gitrdone42 is offline
Send a message via AIM to Gitrdone42
Re: blinking lights
im not really sure but the way you are describing the car cutting off osunds like your alternator is going. not really sure though. mine would die like that just b4 it went out.
Old 05-08-2005, 12:21 PM
JESUS Y ADA JESUS Y ADA is offline
Cool Re: Re: blinking lights
DID THE CAR HAD AN ALARM?? MY FRIEND CAR USED TO DO THAT AND IT WAS THE ALARM AFTER THEY TOOK IT OFF IT WORK FINE.
Old 05-08-2005, 09:56 PM
Re: blinking lights
most of the times the car will die because the rpm hits 4000 or more. the engine will shut off. but it can start rite up again after it dies. kinda weird how i put the car on neutral and rev it to 4000 and just died without the car moving. help guys
Old 05-08-2005, 10:13 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: blinking lights
Sounds like possibly your alt. is shorting internally. Causing the up and down varing voltage making your lights appear to blink. And if your voltage reg inside the alt. is bad it can short out causing the car to die as in the case when you rev it up past 4000 making the reg shuts down the car.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 05-09-2005, 05:59 PM
Re: blinking lights
it's the alternator. a diode (or more) on the rectifier bridge is shorted. that is causing u to send an A/C current thru u'r circuits. the distributor, fuel pump, ECU (etc.) can't work on A/C so that's y it's cutting out. also could be an open in the stator in the alternator. that would cause a flux in the available voltage. if it was bad enough it would almost be like turning a switch on an off real fast. however this would be less apparent as the rpm's climbed, so that prolly isn't the case since u die at about 4k and up. i'm betting on the rectifier bridge, which i do believe is replaceable in a honda alternator, but u could prolly get a used alternator from a yard for the same price as a new bridge.
