Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-04-2005, 04:58 PM
greenmonkey's Avatar
greenmonkey greenmonkey is offline
Question no power to pass wheel
well i have figured out i no longer have power going towards the passenger side wheel. it happened on the way to school today when i ran off the road and the wheel hit a giant pot hole on the side of the road. after getting it home and putting it up on jackstands i discovered i had no power going to the pass. wheel. the transmission is turning but after the first CV joint, there is no rotation. i believe that i am going to have to replace the entire axel or is there a better way?
Old 05-06-2005, 01:25 AM
BullShifter's Avatar
Re: no power to pass wheel
Replace the axle
If the impact was hard enough to break an axle then there might be more problems.
Control arm bent
Bent wheel
Old 05-07-2005, 11:26 AM
im pretty sure that i broke a joint or something. the wheels and control arms look fine. has anyone had any experience in replacing an axle? i plan on replacing it myself but after looking through the manual it seems a little complicated.
Old 05-07-2005, 04:49 PM
97integrals's Avatar
97integrals 97integrals is offline
Re: Re: no power to pass wheel
It is actually really simple, just get a Haynes or Helms manual and follow the steps. Even though it's your first time it shouldn't take you to long to get it fixed. Good luck!
Old 05-07-2005, 05:35 PM
Re: Re: Re: no power to pass wheel
yup, great minds think alike. already got a haynes, following the instruction and im about half way through removal. been pretty easy so far ad i should finish the removal tomorrow
Old 05-07-2005, 10:47 PM
Re: Re: Re: Re: no power to pass wheel
The hardest part is removing the axle nut. We have a 3/4" 1000 ft lb impact at the shop and that even struggles once in a while.
