Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 05-04-2005, 03:09 PM
shiftanfly shiftanfly is offline
Send a message via AIM to shiftanfly
2 problems
first problem...once in a while i'll hit the brakes an then proceed to put on a directional...an it wont work...once i release the brake the directional will then work...now this problem started to occur bout 2 weeks ago an goes an comes here an there...mad fuckin annoying any one have an suggestions as to what i should do or what the problem is?
second problem...few weeks ago my horn sounded as if it was dien...it would sound weak as fuck like a dying duck almost an then it didnt work an worked an now it hasnt work for the longest time...could it be wires to the horn...i know for shure its not the fuse cause i checked that...or could it be the horn its self...it appears to be damaged...
Old 05-04-2005, 04:16 PM
boschmann boschmann is offline
Re: 2 problems
Problem one is probably corroded connections at the tail ligh housing, pull the six-wire in-line connector & look at the terminals. Problem two sounds like a dead horn. You'd have to check for 12V power & ground at the horn (with key on & horn button pushed).
Old 05-05-2005, 04:34 PM
Re: 2 problems
aight dope...yea cuz like the tail light should be fine cuz i had a new light fixture installed..ur prolly rite with the corroaded connection..i've noticed moisture back there
