Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 05-04-2005, 12:11 PM
orv2485 orv2485 is offline
91 Daytona ignition problem ( No Spark )
I am setting my 91 Daytona 2.5L up for a local track ( Oval ). Car ran great up till 2 weeks ago. Now I have no spark at the coil wire. I have 12 vlts at the positive side of the coil but no ground on the negative side of the coil. I checked the negative wire going to the PCM and it is good. I have changed the Hall effect pick up, checked the wires from there to the comp and they are fine. It is looking like the PCM is the problem, but would like to be sure before I drop a couple bills ( 200 ) on a non returnable part. Any help would be much appreciated.
Tom
Old 07-23-2005, 10:51 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: 91 Daytona ignition problem ( No Spark )
Bad coil?
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 07-23-2005, 11:40 AM
Re: Re: 91 Daytona ignition problem ( No Spark )
[quote=93_R/T_TT_Stealth]Bad coil?[/QUOTE
After many hours in the garage, I discovered the 60 pin connector on the PCM was bad. Problem solved and racing every Saturday night.
Tom
Old 07-24-2005, 01:32 AM
oh ok -that'll do it for ya - atleast u found out what the problem was - sorry couldnt be of any assistance....
good luck with the racing!
Old 01-22-2006, 04:57 PM
submachine69 submachine69 is offline
hey how did u find out the connector was bad, because im having a charging problem with my 91 dodge daytona 5-speed, and it seems to be the computer cause it has a new alternator and all the wires are good, but it still will not charge.
