Old 05-04-2005, 08:53 AM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
difference between NT and Turbo Cams, and Pistons
ok I have 2 questions. 1) Can I just take some turbo cams from a stock GST so I can run a little boost on my NT car until I get done rebuilding my other engine? 2) whats the difference compression wise for the NT and Turbo pistons? Thanks in advance
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-04-2005, 04:15 PM
Re: difference between NT and Turbo Cams, and Pistons
BUMP
please help me I need this
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 05-04-2005, 08:52 PM
macder macder is offline
Send a message via MSN to macder
The intake cams are the same for the turbo and NA versions but the exhaust cam is different. I belive the turbo has a slighly more aggressive exhaust cam. The NA has high compression pistons while the turbo has low compression pistons to save room for all that air flow the turbo brings in. The compression for a 4g63na is 9.2:1 and the 4g63t is 7.8:1. Hopefully that answers you question.
Beats the sh*t outta me why i have to do you research but im bored.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 05-04-2005, 09:21 PM
well ill prolly leave these pistons in and just change the cams for now(both) and just boost 10 psi or so
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 05-04-2005, 09:59 PM
IMO You shouldn't run more than 6psi on a 14b turbo (stock 1g) installed on a NA motor, you might be able to run little bit more boost on a T-25 (stock 2g) since it's smaller. With a 9.2:1 compression you don't have room for much air flow from the turbo inside the combustion chamber. It's allways better to be safe then sorry.
Also, have you considered looking for a used 4g63t motor, this may be cheaper (not allways) and be much less hastle. I mean, there's just so many things that could go wrong turboing a NA motor. If you do decide to turbo the NA, it's very wise to re-build the motor while at the same time installing your lower compression pistons. There's lot more to it then just pistons & cam's, for one an oil cooler and the rad is different for the turbo. Anyways do a search, there's plently of info on what to expect, and what you need to turbo a NA.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 05-04-2005, 10:26 PM
welli have another engine sitting im my garage that im rebuilding. vavles, spring, retainers, pistons, rings, fuel pump, ECU, injectors, port and polished head, .40 over bore. that all comes after i just bolt on my turbo on my NT i have to get the ECU right now and injectors and cams then all the needs for turbo. it will cost me about a grand to turbo my NT with a 14b.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 05-05-2005, 12:40 PM
Good luck w/ your project, let me know how it worked out in the end.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 05-05-2005, 03:44 PM
will do
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
