Old 05-04-2005, 09:29 AM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Question Shifter Question
I have a Hurst Competition Plus 4 speed shifter. It’s “rickety” for lack of a better word. Like, you can hear the rods banging into each other when you move the stick. While reattaching the shifter to the transmission (and thank you all for you help with that) I noticed that the nuts holding the rods onto the shifter were not tight, leaving a little play in the rods. The nuts were not LOOSE, just not snug against the rods.
Occasionally when you shift out of reverse it gets stuck and you have to wiggle it to get it out. (HAR!) After that sometimes it gets stuck in first, and same thing, wiggle it and it comes out of first and then it’s fine for a while, every once in a while it’ll do it two or three times in a row (meaning every time you use reverse).
Should I tighten up the nuts that hold the rods onto the shifter to eliminate the play and the rods coming into contact with each other? Will that fix all these issues? Or is that a bad idea?
Thanks
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 05-04-2005, 09:31 AM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: Shifter Question
the last 2 shifters i had installed were tight, but dont over tighten them. i have had one come loose before and do that
Old 05-04-2005, 01:26 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
tighten them and if it fixes your problem well then there you go... if it makes it worse then go back and loosen them....
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
