Old 05-04-2005, 08:27 AM
jg95 jg95 is offline
thermostat gauge
my thermostat gauge isn't working, what could it be? how many o2 sensors are on my 95 4.3 W?
Old 05-04-2005, 10:18 AM
smokey041369 smokey041369 is offline
Re: thermostat gauge
the temp sensor may be bad
should only be one O2 sensor on the exhaust crossover pipe
Old 05-04-2005, 01:48 PM
Question Re: Re: thermostat gauge and transfercase
Thanks for the input.
Old 05-05-2005, 05:37 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I would agree with the temp sensor being bad...
As to the 02 sensors, if you're ECM is under the hood on the coolant tank, then you will have either 2 or 3 (depends on the revision) if your ECM is under the dash you will have 1 or 2 (again depends on the revision)
Under the hood=1st revision ODBII
Under the dash=ODBI.5
Old 05-05-2005, 06:27 AM
I am pretty sure it is OBDII. see I thought there is three, I got a code for upstream O2 Sensor (code Po131).
Old 05-05-2005, 06:29 AM
rlith's Avatar
If the ECM is under the hood, you will definatly have one pre cat and post cat, and you MAY have on on the passenger side manifold on the down pipe.
Old 05-05-2005, 06:36 AM
Question Re: thermostat gauge
Should they all be the same or is each one different?
