Old 05-04-2005, 05:59 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Front End Checks
What checks can I do at home to test the frontend componants?? I know to rock the wheel top to bottom to check the bearings. What about tie rods, ball joints etc??? Thanks!
Old 05-04-2005, 04:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Front End Checks
side to side rocking of thire while it is off the ground will test play in the steering assembly.
Watch the tie rods etc while turning the wheels with you hands on the tires.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-04-2005, 08:57 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
You have to jack the front end up from under lower control arm. If you jack it up from frame the spring or torsion bar will load ball joints with pressure and you will not see the play. When you have front end off ground take tire from 12 & 6 oclock position and shake. Then grab tire at 10 & 5....Then 2 & 7 oclock position. Shake and watch play at upper and lower ball joints. Now at 3 & 9 position watch tie rods ends, pitman arm and idler arm for movement. Take your hand at all theses jionts and try to move them up and down. Movement shows wear. With this kind of wear the front end will have to much play for alignment. And yes you will also see if wheel bearging is bad but you will most of time have roaring noise with wheel beargings.
Old 05-05-2005, 06:32 AM
Re: Re: Front End Checks
Thanks - I was looking for specifics. I don't have time or $$ to see mechanics for every little thing. This info is very usefull to us DIYer's especially with the frontend probs the Blazers have. These kind of detailed posts would make great stickys. Otherwise people have to search tons of old posts in hopes of finding an answer.
Old 05-05-2005, 09:51 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Re: Re: Front End Checks
Not so. I found this thread by using the "Search" function on the top right corner of the forum's main page in just 5 seconds. Proof that searching works!
Old 05-05-2005, 10:08 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: Re: Re: Front End Checks
I found it because it was at the top of page 1. Proof that laziness works!
Old 05-05-2005, 10:13 AM
blazee's Avatar
Problem?
Excellent post!
Old 05-06-2005, 09:13 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Yes sir..this is exactly how they diagnoised my lower ball joints and pitman arm issue....jacked the car up by the frame, then lowered just enough with jack stands in place on the lower control arms to relieve pressure....great tip !
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
Old 05-07-2005, 07:14 PM
Yes searching works but it can take a lot of time going post to post to find the answers needed. Also some of us don't live in areas that have hi-speed internet and it takes even longer. My point was that a single post that covers an entire subject would be great for future searchers.
Old 05-12-2005, 12:55 AM
save_me_jebus save_me_jebus is offline
What is the easiest way to do it on a Arm style hoist? ( has 4 arms that swing under the car)
Old 05-12-2005, 07:18 PM
rksnc's Avatar
Better to use floor jack under lower control arm. Jack up wheel off the ground and check for play.
