Old 05-04-2005, 12:52 AM
jimmysfb jimmysfb is offline
Send a message via AIM to jimmysfb
Frozen Fuel Pump replacement
I need some advice...I own a 91 s10 blazer 4.3 4x4 with 120000 miles. There has been a pretty great loss of power over the pst few months. I want to change the fuel filter, but the threads that hold it to the steel fuel lines are rusted on. I have tried spraying penetration fluid on it, yet it hasnt worked to loosen the nuts. Can anyone think of another way to fix this? can I somehow cut the lines and use a different filter without threads and reattach it with some rubber hose and clamps? Any advice would be greatly helpful. Thanks.
Old 05-04-2005, 05:23 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: Frozen Fuel Pump replacement
you could, but just remember( if you ever go off road) that you have rubber lines underneith. i ve heard of some doing it.
have you tried using 2 pairs of vicegrips to loosen it?
Old 05-04-2005, 06:19 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Use line wrenches... That way you can apply the torque needed without damaging the nuts..
Old 05-06-2005, 01:35 PM
Unhappy Thanks
I didnt want to use vice grips. I used flare wrenches, yet, to no avail. That filter is not comin off and I do not wanna mess up the lines. I appreciate the advice, yet I do have another question...
How would one cut the lines? They are rusty and steel. Obviously, i would not use a torch or hacksaw, a spark near the fuel system can really cause a problem. I was wondering what would give it the cleanest cut, without crimping or ruining the line. If you can help me, I would appreciate it! Thanks.
Also, if you wanted to IM me on AOL or AIM...jimmysfb
Old 05-06-2005, 01:37 PM
rlith's Avatar
Re: Thanks
Wire snips...
Old 02-07-2006, 06:16 PM
brosko80 brosko80 is offline
use a pipe cutter like the one plumbers use to cut copper tubing, just clamp it on and then spin it around tightening it ever once in a while until it cuts through. it has a sharpened disk kin dof like a pi zza cutter. that should do the trick perfectly.
