Old 05-03-2005, 10:34 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
starter or not?
after a new tranny install on my cousins 97 GS-T spyder(5spd), the car started just fine and made a trerrible rubbing noise that seemed to be almost a high pitch rubbing noise(very loud). also the starter smoked when we started it.... did i mess up his car or what? or is it somthing else?
im positve i wired every thing correctly too.....i also tightened the 2 starter bolts pretty tight too.....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
