Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 05-03-2005, 10:28 PM
carpunk carpunk is offline
Beetle Fever
I've kind of admired the beetle since i seen one with a turbo on it at a car show in laughlin Nev. last year. I don't know alot about beetles but i have been reading mags. what is the difference between a long block and a turnkey motor. I know the turn key is basically a drop in and fire up but what is needed with the long block to make it run?
Old 05-03-2005, 11:13 PM
BoatCop's Avatar
BoatCop BoatCop is offline
Re: Beetle Fever
A "short block" is just the case, with internal parts (cam, crank, connecting rods, oil pump, etc) ready to bolt on the pistons, cylinders, heads, push rods, etc.
The long block is just the case (and internal parts), cylinders (with pistons, push rods, push rod tubes), and heads.
To make it inot a complete engine you need manifolds, exhaust, carb, distributor, fan shroud, cooling tin, generator (or alternator), fan, belt, generator stand and oil fill, oil cooler, pulleys, coil, plugs, wires, oil pressure sender, clutch, pressure plate, muffler, and a few things I may have forgot.
The long block is for someone who has all those things on a blown engine, and just needs the "center section" mechanics to get going.
A "turn key", is, as you said, ready to bolt on and go, with maybe just the clutch/pressure plate and muffler needed. For someone (like me and my baja project) who has the bug, but no engine.
Alan
BoatCop
