Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-03-2005, 10:18 PM
Celica_GT_SWB Celica_GT_SWB is offline
Send a message via MSN to Celica_GT_SWB Send a message via Yahoo to Celica_GT_SWB
turbocharged celica
i got a turbocharger for my celica, but havent installed it yet, im afraid the stock parts in my car cant handle the compression. what do i need to replace? i know i need a new clutch, cams, and valves, but what else, i know im missing some things......thanks
Old 05-04-2005, 04:19 AM
Entity_101's Avatar
Entity_101 Entity_101 is offline
close but not so,
you need a exhaust manifold thats gonan go into the turbocharger, the intake part is much simpler, unless you run a carburettor (someone else can fill in about manifolds and intakes) you need to look at your compression, luckily most toyotas are low compression for 4 cylinders, like 8:1-8.5:1 however celicas being a sports model might have a higher CR. it needs to be lowered, 8:1 is great. youl need suitable internals for the boost you want to run, higher boost (prolly over 7psi) will need forged pistons etc, porting and polishing is good but not nececarry. ive notmuch experience on this but for higher boosts on alloy blocks tc you should look at sleeving etc. The work you said will all go towards a more pleasing experience with a turbo'ed car. like i mentioned earlier, internals (pistons, conrods, crank maybe even ) are really important to prevent you doing damage like throwing a rod. other than that i cant remember, proper tuning of the ecu is important, and looking at the fuel system is a must, suitable flow electric pump and injectors so the car doesnt starve itself. Please other poster add more
Is that a metaphor or are you just speaking crap.
Old 05-04-2005, 12:23 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: turbocharged celica
well if your gonna run low boost, being under 7 PSI i wouldnt worry about the compression that much. MY car has a stock 9.5:1 compression and im running 7 PSI with no problems. The most important thing is tunning. I cant stress that enough with FI. TUne TUNE TUNE TUNE! You can have the best built engine in the world, but if it isnt tuned right it will blow in a second. Get your self a nice Emanage system, and have to dyno tuned.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 05-04-2005, 03:59 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
new clutch and flywheel are in order. Not sure how strong the differential is on the car. Injectors and fuel pump will certainly need to be upgraded. New cams and valves are not neccessary, unless this is going to be some 600 whp monster.
Pistons and rings, and rods are always good to have, but arent always neccessary. 2000 SVT Contours with 10.25:1 compression hold up just find to about 10 psi of boost. As long as your rings and ringlands are strong enough, you should be alright. But if you do decide to go with forged pistons, I honestly would recommend about 9:1. A lot depends on your turbo size too. If your going with a small turbo like a T-28, then you could go with 8.5:1 or so since its a very quick spooling turbo. If your going to go with a T3/T4, i would certainly stay around 9:1 - 9.5:1 to help you with your low end power since that size turbo on a little 4 cylinder wont make full boost until about 4,500 rpm's or so. The crank is fine. It will take more than you can throw at it. Upgraded bearings are always highly recommended.
Other things that are needed are turbo manifolds, wastegate, blow off valve, downpipe, intake piping, plenty of silicone hoses, intercooler is highly recommended but not neccessary, and of course a tune preferably dyno tuned.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-12-2005, 11:50 AM
Vip09 Vip09 is offline
Send a message via AIM to Vip09
I very highly recommend getting a pre-fabbed kit for a 7th gen celica. These cars are kinda tricky to get right.
Check out C2 Power's turbo kit for the 1zz. It's a very nice kit.
http://www.c2power.com/products/celi...age1_turbo_kit
Also, for all your internals check out MWR (MonkeyWrench Racing).
http://monkeywrenchracing.com/toyota..._packages.html
Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
Best Alltrac times: 1/4: 13.3 @ 102mph (older setup) 1/8th: 7.8 @ 83mph (old setup)
