Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 05-03-2005, 07:01 PM
vis_inc vis_inc is offline
AC Compressor kicking on and off?
Hey I was wondering if anyone has had a problem with there AC compressor kicking on and off with out the AC setting on. I have the setting on Heat in the cab and set on Vent. It baffels me and I called the dealer and he said he has never came accross this problem before only with the AC on and refrerigerant level low this occurs?
ANy ideas?
Thanks
Old 05-04-2005, 09:36 PM
t-bank t-bank is offline
Is it just on heat or defrost? The compressor will cycle on and off intermittently by design in the defrost mode.
Old 05-04-2005, 10:01 PM
The temp control is set to Hot
The setting is set to vent.
It is not set on Defrost setting
Old 05-05-2005, 01:22 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: AC Compressor kicking on and off?
Well you didn't say what model you have. There are some that the fan control turn to left for AC and turn to the right for heat. There are some models that have a bottom to turn AC compressor on and off. Outside of that clicking on and off that much can also mean that it is low on freon depending on outside temp.
