Old 05-03-2005, 06:05 PM
Beave Beave is offline
Temp Guage Says im getting hot
I just bought a 97 blazer and when im driving it the temperature is fine, but when i put it in park thats when the temp rises. Can i not have enough engine coolant? and if it is this can i just pour some of this dexcool stuff directly in?
Old 05-03-2005, 06:50 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: Temp Guage Says im getting hot
It is possible... Wait until your vehicle is completely cool and open the radiator cap. The coolant level should be up to the top of the radiator spout.
If you're missing any coolant you must have a leak somewhere. It may be your radiator or even your intake gasket. You can add fresh 50% dexcool mix directly to your radiator if it is low, but it may be only a temporary fix if there's a leak.
I would do the check coolant level first, if it is fine I would investigate the water pump- let us know what you find!
Old 05-03-2005, 07:15 PM
the car is still hot but i went just to take a look around and saw a pretty good amount of leaves stuck by the radiator so im gonna clean that out and see what happens. also i was driving it and whenever it reached a certain point it seemed like it would send coolant through and it would coool down; hopefully the leaves help
Old 05-03-2005, 07:22 PM
chcknugget's Avatar
It sounds like you're low on coolant.
Definetely look under the rad cap when the vehicle has cooled down for a couple hours.
Old 05-04-2005, 12:08 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, check the rad level when the engine is dead cold in the morning.
If low, I would replace the rad cap, top off the radiator, and make sure the overflow tank is up to the appropriate level.
You might have to check again the next morning after the rad cap install seeing you will probably have to top up the rad again for the next couple days as the air is being forced out of the cooling system.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-04-2005, 08:28 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I had this same problem on my 98. The factory rad cap was failing and I ended up squirting some coolant out of it, it wasn't keeping the pressure. So got a Stant cap, topped it off with a pre-mix dexcool, installed the new rad cap and no problems since. Not saying that is all you have to do but I had the same symptoms and this is what cured it. Good luck
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-04-2005, 09:17 AM
my mom is taking it to the mechanic today cause i need to drive the car this weekend for a 40 min trip; hopefully it doesnt need a new water pump and just needs a little dexcool and there arent any leaks.
Old 05-04-2005, 09:47 AM
chcknugget's Avatar
Did you even look under the rad cap?
Old 05-04-2005, 04:15 PM
BlazerLT's Avatar
AF -Advisor
Comon man, get off your butt and go out yourself.
Why are you wasting our time if you are just taking it to the shop.
Old 05-04-2005, 06:40 PM
it got new brakes while it was at the mechanic he checked for leaks and check the water pump everything check ok and put in some extra dexcool
thanks for everyone's help
Old 05-04-2005, 06:47 PM
chcknugget's Avatar
You still might want to make sure the radiator is full. I would add coolant to the reservoir but airlock would keep it from going all the way into the radiator.
I'm glad there are no leaks!
Old 05-04-2005, 06:53 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Temp Guage Says im getting hot
replace the rad cap.
It costs $5 and will solve the cause of the problem.
You just adding coolant will not fix it. You will overheat again and sooner or later destroy your engine.
Listen to us please, we aren't stating you to do it for our own good.
Old 05-04-2005, 09:30 PM
coryhawkins coryhawkins is offline
Re: Re: Re: Temp Guage Says im getting hot
Overheating while stopped is a common problem for cars with a partially stopped-up radiator. You may need to take it off and have it boiled and rodded out. I have had to do this on most of my older cars (72 Skylark SunCoupe, 85 Blazer, 86 IROC-Z) already. My 98 Blazer has yet to need any radiator work, other than the new cap. The GM one blows and lets air bubbles get in, so you can hear them in the heater core when you are pulling a hill. The proper Stant cap from Pep Boys (Autozone gave me the wrong one) fixed the air bubbles for me.
Old 05-04-2005, 09:42 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Temp Guage Says im getting hot
This is true in some cases, but for this one, he has a leaking rad cap that is not holding pressure and lower the boiling point of the coolant.
Old 05-04-2005, 10:07 PM
ill go tomm and get a new one
