Old 05-03-2005, 04:17 PM
MRogers's Avatar
MRogers MRogers is offline
Where To Buy a Long Block?
My 89 4.3 has 211,000 miles on it. It smokes on start up, the starter is going, and it's rustier than a boat anchor. Does any body know of a good place to get a cheap rebuilt long block in the NW Ohio area or a place than ships relatively inexpensively? I've decided that I didn't want to mess around with a used engine because of inherent problems with used things. Any help is appreciated.
'89 S10 Blazer 4.3 V6 4X4 with LOTS of rust.
Old 05-03-2005, 04:31 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Where To Buy a Long Block?
You want to replace it because of that?
The smoke at start up is because of worn valve seals. Not really a big deal and not that hard to fix.
Starters are easily replaced.
211,000 really isn't a lot of miles for a 4.3L.
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
google it! that is probibly your best bet, or something like the yellow book or yahoo yellow book
Old 05-03-2005, 04:43 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This is not a sign of an engine needed to be replaced.
This is the sign of an engine that needs some maintanence done to it.
Valve seals are easy to replace.
Starter is easy to replace.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-03-2005, 08:25 PM
MRogers's Avatar
I can't get the heads off because the exhaust manafolds are rusted to the heads and the oil leak is between the passenger head and the block. The amount of smoke that comes out of this at startup is outrageus. It has taken 4 quarts of oil since November to keep it topped off, only about 1500 miles. I want this to be a reliable daily driver as well as an occassional powerful offroad vehical and I don't think this engine can take it. I forgot to mention that it doesn't have very good torque either. I want a new engine because everything on an engine this old is a pain to work on because of the rust and crud that has collected over the years. I have googled and the best price I've seen was $1000 plus about $300 to ship because they are in Washington state. Link http://shop.rebuiltengines.biz/chevy..._282vbl_3.html
Thanks
Old 05-04-2005, 12:17 AM
BlazerLT's Avatar
AF -Advisor
Sounds like it isn't a head gasket, it is a valve cover gasket needing replacing.
Old 05-04-2005, 12:44 AM
find a sb, if your putting the time and mony into a swap that you want for a "powerful off road and daily driver" a moderitly modified 350 will do nicly in there
Old 05-04-2005, 01:02 AM
MRogers's Avatar
The valve cover gasket is fine. Oil is coming from between the head and the block. I'd rather replace the engine now instead of waiting for it to crap out on me when I'm driving down the road. The engine doesn't instill confidance in me. I don't trust for long trips. I want a new engine half because it WILL need to be replaced at some time and half because it would make me feel better.
I thought about a 350 but I really don't NEED it. A 4.3 will drop right in easily and will allow it to handle better too. I have a, *cough*, Mustang, if I want to rip up the road. The 4.3 is quite powerful for what I want and gets decent mileage. One of the things I was hoping to accomplish by swapping the engine was to get the most MPG out of the blazer as I could, like with a cold air intake, low restriction exhaust, new o2 sensor, electric fan, etc. and be able to pass emisions if they start doing testing in my county.
Thanks for responding.
Old 05-04-2005, 06:38 AM
well if you put the 350 in, you would know what a real sports car felt like, jk, and you make sence when you say you dont need a 350, and you shouldnt need a long block, your accesories will transfer over, so why not a short block?
Old 05-04-2005, 06:49 AM
blazee's Avatar
Problem?
Short blocks are a bad idea. After replacing the old stuff that isn't good enough to transfer and the work that is involved getting it preped, it would be easier and cheaper to go with a long block.
mrfirebird mrfirebird is offline
jasper engines, advanced auto, gm crate motor(very expensive), i've been lookin around too.
Old 05-04-2005, 02:10 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
I can tell you where not to get one. AutoZone. I made that mistake on my '82 Olds. They advertized the most new parts on their rebult motors, had the cheapest price, the best guarentee, and everything that moved was either re-ground or new. The problem was they HONEST TO PETE used old, used valve springs. I still have the proof sitting on my desk. One of the valve springs tested out at 30 pounds compression as compared to 80 pounds compression on a new one. The problem is, the only place this shows up is during emissions testing. Compression tests didn't show it, nor did leak-down tests. All I knew was that i could not pass the hydrocarbon test for 3 years after installing a fresh motor. I didn't stumble across the answer until I blew the head gasket and had to have the heads re-done. The problem is, the weak spring doesn't have enough strength to close the valve, and if it is an exhaust valve, you will get unburned fuel in the exhaust gas, which is what is known as hydrocarbons. After I replaced all 12 springs for $1.25 each, ($15.00 USD + tax, total) I called Autozone in Tennessee and complained. Their response was that they could not afford to raise the cost of their rebuilds to include new springs, and furthermore would continue to use old parts as long as they met spec. So where ever you go, be sure you're getting a good quality motor from somewhere you can get warranty service from if necessary.
Old 05-04-2005, 08:28 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Hay ya Properformance Engines are a good buy. 3 Year ,100,000. Mile warranty. Their number is 1-800-595-2513. I buy all my engines from them and have for over 6 years now. I have only had to warranty 1 engine in this time.
Old 05-04-2005, 10:51 PM
MRogers's Avatar
I thought about getting a short block but my heads are half of the problem. I would have to have them rebuilt anyhow. I'm not an experienced engine builder so I would prefer that all of the specifying and clearancing be done for me which just leaves the intake, oil pan, manifolds and such to be put on. I just don't trust myself with the internal workings of an engine that I need to be reliable on a daily basis. At least if an engine I buy breaks, there is a warranty, not the case if I do it myself.
Jasper's engine would be twice as much as the other place. The place I found looked decent and they had a 7 year 70,000 warranty which would be better for me because I put about 10,000 miles a year on my Blazer.
I will look into Properformance tomorrow.
Thanks for all the input.
Old 05-05-2005, 08:36 AM
Big Tall Dumb Ass
Re: Re: Where To Buy a Long Block?
I agree completely, the best, fastest, and usally cheapest in the long run, is to go with a long block. Besides, the warranty is usually better too.
