Old 05-03-2005, 04:15 PM
Jackie Morris Jackie Morris is offline
air in heater core/cooling system
Has anyone had trouble getting air out of your cooling system after a thermostat change? Mine is going on over a year and after you shut the engine off you can place your hand on the top hose and feel it pulsing with the air coming up and you can hear the heater core gurlge sometimes.
1995 Z71 213,000 miles
Old 05-03-2005, 04:49 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: air in heater core/cooling system
From what i have heard that means your heater core is pluged an you need to replace it.
Old 05-03-2005, 06:28 PM
jveik jveik is offline
some of them just do that i think
Old 05-03-2005, 10:42 PM
72 rs's Avatar
72 rs 72 rs is offline
mine is new in my 87 and i have the same prob. i never could get it to stop
Old 05-04-2005, 03:21 PM
bracketshark bracketshark is offline
Re: Re: air in heater core/cooling system
Has the intake gasket been changed? The correct intake gasket has a orface hole in the back water jacket crossover on both gaskets. Check your radiator cap and reservour (?) also it should purge itself of trapped air. I used a vortec block with the TBI heads on my 90, this will not work and be able to run a thermostate. There is a hole in the front of the block on the passengerside below the lower water pump mounting hole that is not drilled on a vortec block it connects to a hole in the block deck that passes water thru to the head. Water will not circulate correctly on the passenger side head causing this head to run hot and other noises and problems will arise. Been there done this, its not fun.
