Old 05-03-2005, 03:39 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Header Bolts
What size are the bolts that are on the exhaust manifold that go into the block? Exact size and dimesions. Also, can I use a OEM gasket for an aftermarket header?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-03-2005, 05:52 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Header Bolts
Yes you can use an OEM gasket... try lining it up with new header and trim anything that overhangs openings....
As for bolt size/lenght... I dunno.. if I come across it before someone else I will post it... otherwise call a mitsu shop for the info... if they don't know they are lying..
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 05-03-2005, 06:12 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
you mean in the head,should be 8mm if i remember correctly.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
