Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 05-03-2005, 02:26 PM
rmackey1969 rmackey1969 is offline
1987 Civic stalls at an idle
Hello all, hope someone can help. My 87 Civic 1.5 liter engine starts fine and runs fine. Problem is after the high idle is done the car will not idle. It drives fine but as soon as I slow or downshift, the car stalls if I don't keep the accelerator applied. Usually idles @ 1000 rpm. Channged the fuel pump but no help. Would appreciate any help!
Old 02-15-2006, 02:54 PM
sweety1080 sweety1080 is offline
Re: 1987 Civic stalls at an idle
i have the same problem and i still can't figure it out. usually before i come to a stop i lay off the gas and brakes and let the car run on what it has. if i push on the accelerator it stalls and if i just let it run with very little gas it idles low but won't stall.
Old 02-16-2006, 11:35 AM
avistar avistar is offline
Check the PCV valve. If it is pulled out of it's grommet or not functioning that could be one cause for the problem. JS
If you need one of these send me a PM for details.
Edmonton, AB Canada
