Old 05-03-2005, 01:36 PM
sLADe781 sLADe781 is offline
BG Synchro Shift II
1. Has anyone used or heard anything about "BG Synchro Shift II?" Good? Bad?
2.It's different from the Pennzoil Synchromesh stuff right? Because after reading that one thread about all the metallic stuff that came out of it, I'm gonna stay away from the synchromesh....
3. What do you guys think is better...BG or Redline?
4. Finally, the BG stuff is for manual trannys as well right? Thanks guys.
Old 05-03-2005, 03:15 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: BG Synchro Shift II
i'm happy with Pennzoil Synchromesh, but to each his own.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-03-2005, 04:58 PM
Igovert500's Avatar
blue + red light magnet
Re: Re: BG Synchro Shift II
I don't know much about synchro shift 2...but there are threads on 3si about it, so a simple search should help. Redline is a very well trusted brand and you can be sure you are safe with that.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-03-2005, 06:24 PM
LOL I actually could not find the "search" button on 3si. But yeah, Linebckr49, Vert, have you guys drained the Synchromesh stuff? How does yours look like?
Old 05-03-2005, 06:50 PM
Igovert500's Avatar
You need to be a member to search.
Try this:
http://www.3si.org/forum/search.php?searchid=864333
Personally, from what I've read I've heard people swear by pretty much everything. And I've yet to read any conclusive info that would lead me to believe any of the four (redline, royal purple, synchromesh, synchroshift) to be significantly better than the next. Everyone has their varied results...some think one is great, some think one is horrible....I simply don't know. From what I've read, there is nothing conclusive.
And no I havn't dropped my fluid, but probably will in the next month from the transaxle and see if there are any shavings/particles. Until then, I'm not really worried.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-03-2005, 06:54 PM
G35turbo G35turbo is offline
I used BG and i love it, it just takes about 1,000 miles for you to feel the differnece. i havent really heard anything good about the PENZOIL and i havent use it, it is just cheaper. The BG syncro shift ranges from 12 to 15 dollars a quart and if i remember right i used 2.8 quarts maybe i am wrong. but i am pretty sure 2.8 quarts.
GOOD LUCK
Mahdi
Old 05-03-2005, 08:29 PM
So G35turbo, have you drained your fluids? If so, how does yours look? I'm leaning towards the BG stuff too.....and one more time, BG is different from Synchromesh right?
-Vert, the link you posted took me to a log in screen.
Old 05-03-2005, 09:24 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I used royal purple synchro somthing or other, noticibly better shifting after about 1k miles but not insanely better, second is still a little hard to get into in VERY high RPMs but its getting better and better, only about a thousand miles so far on it.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 05-03-2005, 10:43 PM
Thourun, where did you buy the Royal Purple Synchro stuff from?
Old 05-03-2005, 11:24 PM
i dident really look at the fluid, i feel stupid now but when i changed the fluid i dident think about that. I did the whole proccess in a hurry.
Yes i think BG is different from synromash.
ALL i got to say is from BG all i hear is good and never bad
but from syncromash i hear more bad stuff than good.
But it just depends if ur willing to pay the extra $ and be safe or u can go the cheap way.
Old 05-03-2005, 11:43 PM
Thourun's Avatar
I went to the Royal Purple site and found that theres a dealer two towns over, cost like $8 a bottle I think... and it realy is purple lol.
Edit: when you do this, REMEMBER to take off the FILL plugs first, I took off the transfer case drain plug first and it took me two days of messing around with differnt wrenches and solvents and a blow torch to get it off. Craftsman makes great wrenches BTW and you should get a breaker bar, I ended up needing one and used opart of a vaccume cleaner hose lol.
1995 3000GT VR-4
