Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-03-2005, 11:47 AM
ScottG29 ScottG29 is offline
Send a message via AIM to ScottG29 Send a message via Yahoo to ScottG29
Angry Autolamp problem
I have a 96 Thunderbird LX Sport. I bought it about 3 weeks ago. My car has the autolamp thumbwheel and when engaged the autolamps do not work. In order to make sure that the car had the option I pulled the switch out and there is one black wire comming out of it. Which is what Mitchell says should be connected to the switch. I have a Good connection.. all fuses are good. Any ideas why it doesnt work?
Old 05-10-2005, 05:10 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Autolamp problem
The light sensor/amplifier on the passenger side top of dash may be bad. Try turning the adjusting screw to early and see if the lights come on. The problem could also be the Autolamp relay is bad. It is located under the dash to the right of the steering column and has six wires coming out of it's connector. I'm assuming the lights work normally with the autolamp feature turned off.
Old 05-15-2008, 08:31 AM
93siltbird 93siltbird is offline
i have a 93 bird and it has a digital dash and all of a sudden the dash dont work i checked the fuse and it was all right anyone have any clues i checked all the bulbs and they were fine any help would be appreciated thanks
Old 05-16-2008, 04:59 PM
97Bird's Avatar
Is it just the lights that don't work or the complete dash including the guages?
The Original 97Bird
