Old 05-03-2005, 08:45 AM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
OP gauge
ok my oil pressure gauge is not working at all. I have no idea what the problem could be and I have read in my Chiltons that you have to remove the whole steering colum in order to look at the gauges. I was thinking about puting glow gauges in my car but if thats the case I'm not. But I can't even think of a solution why the oil pressure gauge isnt working.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-03-2005, 04:15 PM
Re: OP gauge
Bump
I need help
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 05-03-2005, 04:41 PM
ted_ex's Avatar
ted_ex ted_ex is offline
Are you sure you have oil pressure? I had a friend who decided for no good reason that the reason his gauge wasn't reading was the gauge was broken. The oil pump was the real problem and he lost his engine. The next thing I would look at is the oil pressure sender that is attached to the engine ( I don't know where on a non-turbo). It's more common for the sender to go bad then the gauge itself. Aside from that It could be a wire or the gauge.
tedX
I'm>everything
Old 05-03-2005, 05:27 PM
Re: OP gauge
i doubt its the oil pump. the neigne only has 50 thou on it.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 05-04-2005, 11:48 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: OP gauge
Thats called making an ASSumption. I would check the wiring to the sender first, then the sender itself. They are only ~20 bucks and easy to change. As mentioned above, its very unlikely its the guage itself. Not much can go wrong with it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-04-2005, 09:15 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: OP gauge
yea check the senders. the plugs break on them. and btw the dont need to remove the whole steering colum to get to the guages.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-04-2005, 09:19 PM
Re: OP gauge
how would i put some GLOWS on.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
