Old 05-03-2005, 06:17 AM
talonx talonx is offline
melted! main wire harness
Well, bad luck hit again.
The passenger side air injection hose/check valve
let go and of course the wire harness that goes to
the PCM(or ECM) was right there and melted all the
insulation off the wires.
99' 2 dr Blazer.
I'm thinking of getting some connectors and doing a splice.
Mainly to see if the PCM and other electronics are o.k.
It's about 64/65 wires.(one looks sheilded)
Maybe later try to get a harness from a boneyard or the dealer.
Most of the ECM and PCM fuses blew.
Any suggestions from experienced GM techs or others are
appreciated.
Old 05-03-2005, 10:34 AM
berniescout berniescout is offline
Re: melted! main wire harness
all computer circuits should/must be low resistance therefore must be soldered. no crimps no wire nuts will be better off with new harness but at what cost?
Old 05-03-2005, 01:15 PM
$600 and change from the dealer. After I heard
the 600 part I blanked out.
Used, a boneyard told me a "couple" hundred.
It looks like a pain to do.
Old 05-03-2005, 06:57 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Sorry man, that sounds pretty crazy.
I would look on ebay, I've seen them for like $5.
