Old 05-02-2005, 09:09 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Finally! Got my BL and Bushings done on the 95 blazer!
Let me start out by saying that this is simply the precursor to my 5" trailmaster lift. (But doing the 5.7 vortec 1st) Secondly, YES, I know I need slightly bigger tires (currently running 31's), 3rd yes, I know I need to crank the torsion bars up a little bit...Pfpfpfpfpf :uzi:
Project was started at 12:00 and ended at around 6:30, took several breaks, including a 20 min one when I crushed my thumb... (ouch)And I did it ALONE! (I did it at grapplers house but he was off playing with his GF)
PA 2" Bodylift and Energy Suspension poly bushings
On to the pics!
Bushings:
Here is my blazer prior to yesterday (5/1/05)
Started with removing the grille, bumpers, and skid plate...
Note: The reason all wheels were remove and the frame was set on jack stands is that with wheels left on, the suspension forces the frame up when the weight of the body is removed... I don't have jacks that high!
Bushings: Side and rear...
Note: My old bushings were rotted to hell. I wish I had taken a picture... A couple of them were completely collapsed.
And of course the final outcome...
Overall it was a pretty easy project. I didn't have to use the gas filler extension, and I didn't need the included 98+ rear bumper mounts.... As you can see in the bushing pics I greased them liberally with black lithium grease to prevent squeaking during break in.... After impacting the new body bolts down (used locktite) I went around and re-cranked them with a breaker bar... I don't think they're coming out. Since I live in Pittsburgh, the body got a lot of workout on pot holes on the way home..and for work today... No squeaks or knocks or looseness on the body. Also very little body roll. So overall I'm pretty happy.
Old 05-02-2005, 10:25 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Finally! Got my BL and Bushings done on the 95 blazer!
Nice work rlith...
That looks sharp, you make this shit look easy.
Where did you get your nerf bars at and did you have to do any drilling into the frame on the install?
Old 05-02-2005, 10:29 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
yet another amazing project from rlith, and it looks damn good keep up the good work
Old 05-02-2005, 10:33 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Great job, may be in my future! So you fit 31's on the stock setup?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-03-2005, 04:14 AM
rlith's Avatar
Yeah, have had them for about a year...My ultimate goal is to squeeze 34's on there... But the new motor comes first...heh
Old 05-03-2005, 08:10 AM
Re: Re: Finally! Got my BL and Bushings done on the 95 blazer!
Good luck with the new motor! So you fit 31X10.5X15? How come everyone else says that is just too big? How much rubbing is there?
K&N Air Filter
Old 05-03-2005, 08:23 AM
rlith's Avatar
I get almost no frame running except at hard lock..
Old 05-03-2005, 08:30 AM
Did you previously adjust the torsion bars before or after you put the 31's on? Only slight rub ha? I may need to throw a set of 31's on then!
K&N Air Filter
Old 05-03-2005, 08:41 AM
rlith's Avatar
Re: Re: Re: Finally! Got my BL and Bushings done on the 95 blazer!
Nope, haven't adjusted them, they are still at stock... Need to crank them up though for leveling... just too lazy at the moment....
Old 05-03-2005, 08:55 AM
Re: Re: Re: Re: Finally! Got my BL and Bushings done on the 95 blazer!
Everywhere I go asys those 31's won't fit.... I will have to try again!
K&N Air Filter
Old 05-03-2005, 08:56 AM
rlith's Avatar
Never had a problem...shrug..
