Old 05-02-2005, 07:44 PM
rbuck rbuck is offline
1993 4L60 Trans codes any body have a clue
59, 67, 66, 73, 81 Any help appreciated
Feels like taking off in second gear Full of fluid just replaced clutch packs had 1st gear about three or four times on test drive.
roasted the tires about 2 times. then no 1st gear or 3rd gear or overdrive
Old 05-02-2005, 11:08 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: 1993 4L60 Trans codes any body have a clue
Dumping that much torque into a '96 4l50e can split your sun gear reaction shell. But this also kills reverse in some instances. Drop the pan and get a look. If you see any slivers of steel bigger than a 1/4 inch, you munched your planetary pack and the shell.
Old 05-03-2005, 12:19 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
2-3 and 3-2 shift solenoid error
Torque convertor switch error
Pressure control solenoid error.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-03-2005, 10:49 AM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
This way to many electrical codes. Just about all solenoids. Some of these code do not show up until 95 models. But it sounds like you have a electrical problems here. The plug at trans not good, loose, bent contacts, harness damage, cut wire, or something. Your solenoid work off 12 volts, your sensor works of 5 volt ref signal. The trans is in fault mode and that is second gear.
Old 05-03-2005, 03:12 PM
BlazerLT's Avatar
AF -Advisor
I think the base problem is the TCC.
That will cause the low power from a stop.
Old 05-06-2005, 09:51 PM
Re: Re: 1993 4L60 Trans codes any body have a clue
Thank will check that out. Going to pickup trans book at libary to help me out also.
Old 05-08-2005, 03:28 PM
rksnc's Avatar
If the tcc stays locked it will do more than that. It will stall engine when you try to stop. If it is engaged there will be no slip at stops. If it doesn't engage then you just don't get the gas mileage because of turning higher rpms. I seen more tcc locks with the front wheel drive cars. And when that happens you will know because it is like you are stoping and forgot to disengage clutch. Sometimes after this happens you can let sit for a while and go again. And also will not engage until it has warmed up.
