Old 05-02-2005, 07:36 PM
Civix's Avatar
Civix Civix is offline
What are the major seals that need to be replaced?
My car is starting to burn a quart of oil a month I think it's time that I need to start getting the seals replaced. My question is what seals usually should be replaced? I don't want to replace the head gasket or anything but which ones. I'm talking both big and small ones here. I just need a rough idea.
With my Civic, I'm Pimping Yo
Old 05-02-2005, 08:30 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: What are the major seals that need to be replaced?
start with valve stem seals, if not, time for rebuild
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 05-02-2005, 10:05 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Re: What are the major seals that need to be replaced?
what he said...but you should have asked in ur other thread instead of starting 2
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-04-2005, 07:00 PM
Civix's Avatar
Sorry, but I thought my other thread is about the clutch mostly and I didn't think I needed to lnclude it in that since I just wanted a direct answer to the question.
Rebuild is not something I really want to deal with since the motor has been taken care of and all and only has 134k on it, it's just I haven't had the time now for 3 years to do anything engine wise. But mostly I should I replace seals around the valve cover and oil pan? Would I need to replace the seals on the valves too or is that costly to do?
Old 05-04-2005, 07:46 PM
kris's Avatar
kris kris is offline
Off playing with fire.
If you are burning oil, you have bigger problems than a oil pan gasket seal.
Old 05-04-2005, 08:28 PM
honda_luvr_2000 honda_luvr_2000 is offline
valve stem seals r about $0.65 each. that's not too expensive if u ask me. a quart a month doesn't mean anything. how many miles r going by in that month? the acceptable oil consumption of an engine is one quart for every 1500 miles. so if u r gettin that many miles then technicly u r ok. an engine will ALWAYS burn sum amount of oil, but i understand the concern of burning oil.
there r only 4 ways to burn oil;
1) valve stem seals leaking
2) worn/broken oil rings
3) head gasket leaking
4) clogged PCV system AND excessive blowby causing oil to back feed out the PCV system fresh air "intake", and then sucked thru the intake into the system.
these will NOT cause oil burning:
front and rear main seals, camshaft seal, valve cover and oil pan gaskets, oil pump "gasket"(there really isn't an actual gasket, just liquid sealer from the factory)
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
Old 05-05-2005, 05:22 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea but all those seals can leak, so he may be losing oil that way, not just burning it off.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-05-2005, 05:41 PM
also check to see if your spark plug holes are filled up with oil, that can cause oil to seep past the spark plugs into the chamber.
-2000 Civic Hatch
-1998 Lexus SC300
Old 05-08-2005, 08:55 PM
Civix's Avatar
yeah, when we did replace the spark plugs, there was a good amount of oil in the sparks plugs and i've known that they've got to be replaced. The PCV has also been replaced too.
Thanks guys for your help.
Old 05-08-2005, 09:50 PM
89ZCCivic's Avatar
89ZCCivic 89ZCCivic is offline
Damm i got the same problem with my car. It wasted about 3.5 quarts in 1 month maybe its becouse i race it evry weekend
