Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 05-02-2005, 06:33 PM
nova1313's Avatar
nova1313 nova1313 is offline
neon's/led fitting questions.
I was about to order a led undercar kit from crutchfield.com but I had a few questions..
The sides state that they are 50" and the front and back are 25".
I'm pretty sure the front and back will fit. But I was wondering from someone who has installed them on the sides how long is a safe length? Do I have to leave clearance for anything? I've never mounted them before.. from my understanding they just go into the frame of the car is that correct?
I tried searching on here for the clearance but I couldn't find anything.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 05-02-2005, 10:29 PM
--- --- is offline
Re: neon's/led fitting questions.
I would suggest you PM David-b, he has LED underbody on his car as well.
I drive a slow car.
Old 05-03-2005, 09:07 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Clearence is no problem. Check your PM.If you need pics I can post them too.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-03-2005, 03:20 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
I would like to see how you mounted them in the back.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 05-03-2005, 03:35 PM
david-b's Avatar
Dave is THAT guy
On the back, it sits ALL the way up in the bumper. You see on my signature pic where the license plate sits? It's directly behind there. It sits on where the lower bumper connects to the upper piece. Its high up, yes... but with LEDs, its still bright. Also lights up your muffler really well. lol. Alittle double-sided tape and a zip tie or 2 works really well to hold it up there. The wire for it then run on the underside of the car, through the back suspension, and along the rightside of the car, along with the right side LED tube and wire
75 Monte Carlo
Old 05-03-2005, 04:14 PM
nova1313's Avatar
Re: Re: neon's/led fitting questions.
I'm going to place an order for them tonight. When they arrive I'll post pictures through the whole install. It will be the biggest thing I have done on my car to date. I just tried to paint some interior parts today.
Needless to say my dad insists that I shouldn't make it look better then it already does because it might attract vandals...
Old 05-03-2005, 04:15 PM
nova1313's Avatar
odd question did you have to jack the car up? (I assume so as it's really really small under there! and if so did you use jack stands? I have two would that be enough or would it be better to have the entire car on jack stands?
Old 05-05-2005, 03:58 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
2 jacks is fine you will just have to move them from side to side and front to back.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-05-2005, 04:58 PM
david-b's Avatar
Dave is THAT guy
I used ramps.
75 Monte Carlo
Old 05-08-2005, 03:32 PM
david-b's Avatar
Dave is THAT guy
Side LEDs. Use a little wire to connect the LED tube to the mount, just incase it breaks. The tube wont drag then. Experience
This one is kinda hard to see. Its the back. On the left is the muffler. Im laying on the ground. The tube is up in the body
75 Monte Carlo
Old 05-08-2005, 04:56 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
When i installed mine the hardest one was the back. I had a wireless remote hooked up in the trunk. I ran all the wires up through the tiny hole under the spare time and hooked them up to the amp kit wires.
Pictures of the Truck
Old 05-08-2005, 09:24 PM
nova1313's Avatar
I now really appreciate the time it takes for someone to install one of these kits. I got under my car today and mounted the side mounts for one of the sides (read about 2 hours of work). I almost took off the back bumper but I think I can get to it without doing that.... I got
http://www.crutchfield.com/S-X9Jd0Lo...00&I=505UL200B
That kit... It's very nice but one problem is the bars are flat. I have to put on on to see how this is going to work for me. Where I drilled the mounts are exactly where you have yours. But with my led's they will actually be facing the underbody of the car and not at the ground. So I have to mount them so they are the other way. I'm not sure how to accomplish this yet... I may have to redrill those four mounts. Thats why I wanted to get just one side on to see how it looks.
I already mounted the switch in the interior and got power from the cigareete lighter. I used a splice connect for a 1in 2 out connector my dad had around (he's an electrician). It worked out rather nice.. I'll post pictures of the work of installing them tommorow along with a how-to and some after the fact pictures when they are done.
Old 05-08-2005, 09:25 PM
nova1313's Avatar
oh on the spyder the back light is a bit harder to mount because of trunk layout it seems. It's actually looking best to go on this lip thats between the bottom of the rear cover lip and on the bottom of the license plate holder. The rear tirewell is obstructing the middle of the light however so I'm not sure how well that will work out yet.
Old 05-09-2005, 11:51 PM
nova1313's Avatar
6 hours later they are on and work. I will post a tutorial with pictures later.
Basically if it wasn't for my dad being really handy I would have been screwed. The mounting hardware they gave you was no good. We had to custom make 8 brackets for the side lights that were essentially 90" bends of aluminum. And odd bends (between 30-45degree's) for the back 4 brackets.
Wiring was fun and involved taking apart the back of the spyder. Which btw I finally found where the rest of the trunk went. It's behind the back wall. There is so much room there thats not used even when the top is down..
I got it all together and it didn't turn on. Here the fuse holder that came with the kit sucked and didn't make connection.
The varad led lightbars are super nice. Very very bright. No dots of light just solid glow as they promised. Definately worth the money. I'm not sure about the time though. It took really long and that was after we had the car jacked up looking for places to mount things and starting one sides holes yesterday for 3 hours.
Had the kit come with decent brackets it wouldn't have taken as long... Also had I not been a perfectionist mounting would have gone alot faster too..
Old 05-11-2005, 10:14 AM
nova1313's Avatar
Tutorial and pictures of before and after below. There are also pictures of the brackets I made for the sides and back.
http://www.novaslp.net/pics/car/lights/
