Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 05-02-2005, 04:50 PM
Canderson Canderson is offline
Angry help with 1995 lebaron gtc.. auto.. sigh
I have a 1995 Lebaron that has 50 k miles on it, my friends think it's slow and so do i, is there any options i have to make it faster? any advice would help thanks. Btw it is auto.
Old 05-04-2005, 12:48 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: help with 1995 lebaron gtc.. auto.. sigh
your best bet is a K & N filtercharger system for it. Exhaust systems are hard to come by for a car 10 years old. If you have the 3.0, it makes some power, but still it's not meant to be a 10 second bracket car.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-04-2005, 04:31 PM
Re: Re: help with 1995 lebaron gtc.. auto.. sigh
thanks for your input, i really appreciate it. But what about putting a 52mm throttle body on it from a old dodge van or something, i believe it would fit?
again thanks
Old 05-04-2005, 04:53 PM
Sorry, i forgot to ask this, do turbonators work? and yes i have the 3.0 L engine.
Old 05-04-2005, 11:59 PM
I've never seen anyone put a different throttle body from a Dodge van, it might work, not sure. As far as turbonators, not sure as well, possibly. It all depends on how much you want to spend to make the car faster.
Old 05-05-2005, 06:58 PM
thanks for the input.
- clark
Old 05-29-2005, 04:28 PM
92lebaronGTC 92lebaronGTC is offline
Send a message via AIM to 92lebaronGTC
52mm throttle body is a popular mod for 3.0's it's good for just under 10hp or so and it changes your powerband a little too so your high end power is better.
K&N cone filter you can attach directly to your throttle body or make tubing for cold air, the K&N RU-0620 will fit directly on the t-body and is only $29.99 at most auto parts places.
Exhaust doesn't seem to do ALL that much on these cars but ofcourse just about anything is better than stock, a good 2.5" pipe and good flowing muffler will do you just fine, all for just a couple hundred at an exhaust shop unless you do it yourself.
You can also upgrade to 8mm wires and a MSD coil/ignition, that's another popular mod.
I'm going to port my intake plenum once I have access to a decent dremel, I heard it's good for about 5hp and makes the car drive better if you do it right.
Just do the basic bolt-ons, and figure out what you want to do from there, there's tons of options available, just depends on what you want to do and spend. There are people with custom turbo kits and superchargers on the 3.0.
http://web.tampabay.rr.com/redroby/3liter/ a good site to mod the 3.0
www.cheetahonline.com is good too. and ofcourse check out www.thedodgegarage.com
Good luck modding!
Old 06-15-2005, 01:42 PM
automan9482's Avatar
automan9482 automan9482 is offline
Send a message via Yahoo to automan9482
What would you want to make it faster for? True, the 3.0 won't get you any impressive strip times, but it has plenty of torque. My stock 95 with 88,000 has no problem getting out of its own way, and can leave those punks who think their tricked out junkers are hot s**t far behind .
Old 06-17-2005, 05:57 PM
icntdrv icntdrv is offline
Send a message via AIM to icntdrv
The easiest way to get some extra "seat of the pants" speed is to change the ignition timing in the car to get some extra power. The more you advance the timing the higher grade fuel you'll have to use and beware of advancing too much or you'll damage the engine with all of the excessive pinging that will go on.
Old 09-08-2005, 02:53 AM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
there are tons of things that you can do to the 3.0L engine to make it faster. One of my friends has a spirit that has 370bhp at the chassis, its been dyno tested. If you are interested more than drop me an e-mail at [email protected]
